BusHunter Posted September 5, 2018 Report Share Posted September 5, 2018 Theres some strange signage going on over by Montrose/Cicero if anyone wants to check it out. It seems the bus stops are lettered making a rather confusing experience I shot some pictures. At Montrose blue line there is an a and b side. I thought it was different route buses but it's not. Pics are from Montrose/Cicero Quote Link to comment Share on other sites More sharing options...
Busjack Posted September 5, 2018 Report Share Posted September 5, 2018 That must be an RTA pilot, as it is exactly the same as at Rosemont and Barrington Road. The 54A sign is the same format as the ones on the Tollway at Barrington Road, which I thought was Pace copying CTA, but I no longer think that. Also that sign had to Rosemont blacked out for 607, which goes to NWTC. The Barrington Road pedestrian bridge had an indication for Stop A on the north side, which I previously noted was not in service. And, predictably, someone spent money on a route to be discontinued. IIRC, the RTA was doing something similar downtown near a Metra station. Quote Link to comment Share on other sites More sharing options...
Pace831 Posted September 6, 2018 Report Share Posted September 6, 2018 RTA Map of Interagency Signage Locations Quote Link to comment Share on other sites More sharing options...
artthouwill Posted September 6, 2018 Report Share Posted September 6, 2018 2 hours ago, Busjack said: That must be an RTA pilot, as it is exactly the same as at Rosemont and Barrington Road. The 54A sign is the same format as the ones on the Tollway at Barrington Road, which I thought was Pace copying CTA, but I no longer think that. Also that sign had to Rosemont blacked out for 607, which goes to NWTC. The Barrington Road pedestrian bridge had an indication for Stop A on the north side, which I previously noted was not in service. And, predictably, someone spent money on a route to be discontinued. IIRC, the RTA was doing something similar downtown near a Metra station. Union Station to be exact. Quote Link to comment Share on other sites More sharing options...
Sam92 Posted September 6, 2018 Report Share Posted September 6, 2018 6 minutes ago, artthouwill said: Union Station to be exact. Yeah they have those up Michigan avenue as well Quote Link to comment Share on other sites More sharing options...
Busjack Posted September 6, 2018 Report Share Posted September 6, 2018 2 hours ago, Pace831 said: RTA Map of Interagency Signage Locations As the one depicted above is Montrose Mayfair on the map, the theory must be that that's where to transfer between the Milw. N. and the Blue Line to O'Hare, as stated in the Metra schedule. 1 1 Quote Link to comment Share on other sites More sharing options...
Sam92 Posted September 6, 2018 Report Share Posted September 6, 2018 7 hours ago, Busjack said: As the one depicted above is Montrose Mayfair on the map, the theory must be that that's where to transfer between the Milw. N. and the Blue Line to O'Hare, as stated in the Metra schedule. So pretty much where both metra and cta intersect is where you will find them. Possibly to help direct city passengers who want to travel to the burbs but not too familiar Quote Link to comment Share on other sites More sharing options...
Busjack Posted September 6, 2018 Report Share Posted September 6, 2018 1 hour ago, Sam92 said: So pretty much where both metra and cta intersect is where you will find them. Possibly to help direct city passengers who want to travel to the burbs but not too familiar Looks like the opposite. In most cases to direct Metra riders to buses, as there would be no need to have lettered bus stops. In this case, directing Metra passengers to the Blue Line. The Barrington Road one must be "Partner Site Using Interagency Standards," although it is not on the linked map. Quote Link to comment Share on other sites More sharing options...
Busjack Posted September 6, 2018 Report Share Posted September 6, 2018 The announcement for the 95th/Dan Ryan terminal indicates it is using the same system. See the indicated pictures in the post quoted below. On 3/31/2018 at 6:51 PM, cta5658 said: Quote Link to comment Share on other sites More sharing options...
NewFlyerMCI Posted September 6, 2018 Report Share Posted September 6, 2018 27 minutes ago, Busjack said: The announcement for the 95th/Dan Ryan terminal indicates it is using the same system. See the indicated pictures in the post quoted below. Any idea why the 29 has two bus bays? Also, is there a possibility of this pilot extending to the Orange Line stations or Howard station? Quote Link to comment Share on other sites More sharing options...
Pace831 Posted September 6, 2018 Report Share Posted September 6, 2018 12 minutes ago, NewFlyerMCI said: Any idea why the 29 has two bus bays? To reduce congestion, as the route is busy enough that there are sometimes two buses there at once. (One pulls in before the other leaves) 14 minutes ago, NewFlyerMCI said: Also, is there a possibility of this pilot extending to the Orange Line stations or Howard station? This signage not a pilot, it is already an RTA standard, but not yet implemented systemwide. These recent examples are being installed in more prominent places, but the signs at some locations such as 95th/Western and Joliet have existed for a few years already. The map I linked to above does not show the locations you asked about, but as @Busjack noted, Barrington Road isn't on the map either. These signs will likely be installed during any station rebuild from now on, and existing locations will be changed as time and funding allows. Quote Link to comment Share on other sites More sharing options...
MetroShadow Posted September 13, 2018 Report Share Posted September 13, 2018 On 9/6/2018 at 11:13 AM, NewFlyerMCI said: Any idea why the 29 has two bus bays? Also, is there a possibility of this pilot extending to the Orange Line stations or Howard station? Reduce congestion, overflow, and/or layover space. Quote Link to comment Share on other sites More sharing options...
andrethebusman Posted October 16, 2018 Report Share Posted October 16, 2018 Service notice for Jeff Park bus terminal rebuilding shows lettered stops. Seems to be spreading systemwide as an effort to help direct people to correct stop in complex areas. Makes sense, easier to say "stop D" than "4th platform in the terminal to your right". Quote Link to comment Share on other sites More sharing options...
Guest Posted January 7, 2020 Report Share Posted January 7, 2020 I like the new redesigned bus stops I dont understand the letters though I wish CTA would redesign that boring logo Maybe do an updated 1950s style??? Quote Link to comment Share on other sites More sharing options...
NewFlyerMCI Posted January 7, 2020 Report Share Posted January 7, 2020 1 hour ago, CTA5750 said: I like the new redesigned bus stops I dont understand the letters though I wish CTA would redesign that boring logo Maybe do an updated 1950s style??? On 10/15/2018 at 8:08 PM, andrethebusman said: Service notice for Jeff Park bus terminal rebuilding shows lettered stops. Seems to be spreading systemwide as an effort to help direct people to correct stop in complex areas. Makes sense, easier to say "stop D" than "4th platform in the terminal to your right". I think this was the goal, although I'm happy to be wrong Quote Link to comment Share on other sites More sharing options...
