6400-series Nova LFS - Updates & Retirements
4 hours ago, Bus1883 said:
Yeah what’s the point of them now. If they’re not using them due to covid.
It's not even covid but whats the point of using them as training buses when only garage that use them is FG & when you first start you gone be at 7 6 3 k if you get lucky C when you first start
1 hour ago, Bus1883 said:
#6710 was randomly awoke earlier today at around 11:00. They’re probably draining the fluids on this bus or something but idk why was it on. @YoungBusLovershould know if he’s available.
IMG_1458.MOV
Well in years past SS mechanics would drain fluids and run the buses until they seized up and shut off. That may be a wrong assumption though.
IMG_1458.MOV
If they are really retired they are draining the the oil & trans fluid then leaving them till run till the motor blows
Exactly they be doing that
I was thinking of that too, they’ll sometimes leave them running for a little while until the engine cuts off for good.
41 minutes ago, Mr.NewFlyer1051 said:
#6710 was at FG the other day when i seen 1767 and 1861 looks like they took it to SS for the final resting spot
Actually #6710 has been at SS for over a year now.
That's what I'm saying really only 6470 & 6488 really the only 2 that had been used
#6488 is the only one I think that’s out there used #6470 is in the boneyard, I hope it gets to see the light of day again.
Yea they blow them imma get around to doing that since I'm starting to be in the shop more now
6488 don't even get used it just sits in the back of the lot C use what they got same as K cause k comes to see sometimes
Dam they drove it out them put it back tf
On 10/11/2021 at 1:06 PM, andrethebusman said:
103 - 6675,6678,6679,6681,6684,6686,6691,6882 (8)
77 - 6705,6710,6713,6714,6722,6724,6730,6734 (8)
74 - 6746,6747,6751,6761,6763 (6)
K - 6772,6776,6780,6784,6787,6792,6794,6799 (8)
C - 6802,6803,6805,6820,6826,6834,6835,6836 (8)
P - 6837,6838,6843,6846,6847,6849 (7)
F - 6472,6859,6861,6865,6867,6869,6870,6871,6875,6877 (10)
@Mr.NewFlyer1051 #6710 has been in the boneyard since April of 2021, Hasn't been moved from that spot in over a year. I'm surprised it's still running at this point.
Yea since last March since they put em out of service again
Yeah, first Covid did a beat down on the old novas in 2020 which result them being pulled OOS to receive new shields, next in 2021 #6860’s fire nearly pulled the rope with almost all being retired, luckily a few #6800’s have returned to service. In 2022 #6838, #6847 and #6875 were reported in the boneyard officially retired in May which is a sign the end is getting closer and closer day by day.
Most def needed a Jumpstart but I wonder what they finna do with it since they had it running
Yea 6838 had its bike rake removed just like how C removed 6836 rack
Posted (edited)
I was very close to typing "It's Over" (and referring in lyrics from Boz Scaggs).
But it's not over. Buses 6843, 6859, 6865, 6869, and 6870 are operating today [7 July 2022]. ?
I'll spare you the Lenny Kravitz lyrics. ?
Edited by pudgym29
A 5th bus went into service.
  • Haha 1
Lmaooo. But still we all have to take advantage and get your last pictures and final rides in before the new 8350s gets closer to be in service.
12 minutes ago, YoungBusLover said:
Yeah it's the final frontier with these 6800s. I would love to see them last long enough before the Fall Pick starts on the 22nd of August.
I think that will cta know they are good buses cause ether have been running 20 years with no rehabs
