4095 down at Cermak and oak park, seems like it has a leak at the rear and has low air pressure, 4089 seems to be replacement bus. A 992 was revving 4095 but the bus wouldn’t move
These buses are showing their age
3 hours ago, Erin Mishkin Jr. said:
Ye true. Now I’m walking past it they’re hooking it up to tow truck 250 I heard the crew said 4095 had a leak
Dam truck 250 must be their only tow truck ive seen it all over the city towing
7 minutes ago, Mr.NewFlyer1051 said:
i be seeing 250 every single day there was this one time i seen the smaller version by NP couple weeks ago
Question is where is 270? 250 is the next closest unit.
7 hours ago, YoungBusLover said:
CTA has a variety of trucks, there is a small #210 and a much larger #210 I've seen used in the past several weeks coming in and out of SS with dead buses.
they got two tow trucks with the same number wow
#210 Has had its work cut out for it in the past couple of weeks. Almost every other night I'm seeing #7900s getting towed back to the garage. Tonight #7924 is broken down at 87th and Wentworth with the front suspension sitting lower than usual. I've seen a couple of #1300s get towed in as well last week.
Them 7900's go weak ass suspension
8308 possible break down near north avenue and Harlem.  Brokr down around 2:20 pm and it was there with a 992 on there run F992 when I went by on the 307 fifteen minutes ago. 8308 was turned on at the time and lights were on, didn’t see any service vans or tow trucks. Saw 8301 pas by it might be the replacement bus. 8301 signs said 91 austin to Roosevelt for some reason…run F165 austin run number.  8308 was block 90-402 when it broke down.
as of 6:30 PM 8308 was hooked onto a tow truck, bus's exterior lights were still on for some reason. 8313 was the replacement bus
8144 will be out of commission for a while. That's if it gets a repair. It caught fire yesterday morning according to a CBS 2 news clip I spotted through YouTube. They say the fire started from the engine. No injuries and no passengers on board at the time. There is fire damage at the rear, mainly some melting of the top rear panels, though it doesn't look as severe as on 4333 when it caught fire years ago during its first winter in service if I'm remembering the timeframe correctly.
