Must be starting at North Shore 6233 is wrapped. I thought I saw another one Wednesday, but maybe it was the same one.
I saw commercial wraps on 2769 and 2772. At first I thought they were food trucks or ice cream trucks. Not much bus showing there.
Wow, what a way to be petty as hell by defacing the original white and blue livery on #6241! I don't think Mel would be very happy about this!
https://www.flickr.com/photos/mbernero/6921760801
Pace 6241 South Blvd-Ridgeland
Posted (edited)
I'll say this, West does it way better than South does.  Looks like the 6262s in my opinion.
Also, some of the South buses still aren't wrapped yet, which I am very surprised.  I don't know if it's because they don't have the time because of the amount of buses they have to have out during rush hour or if those buses could be on the chopping block when the CNGs arrive.
Edited by rotjohns
Posted (edited)
Actually South does it better then West or any other division, as South removes the black rubber trim below the windows, which gives it more of a "6262" look.
Edited by jesi2282
They just don't look refined to me, it almost seems like they just put the wrap together to see if they stick.  It could also be the fact South's buses take a huge beating and probably have to get them done more quickly.  I haven't been up North recently to see those buses so I can't compare as to how they are looking nowadays.
The N and NS buses look pretty convincing, but you can see the decals through the wraps if you are close up.
Posted (edited)
One must remember that everything from 6262 and above are actual livery and not wraps.  If decals aren't 'taken off before wrapping, then those decal imprints can still be seen if you look very closely.  Otherwise stripping decals and priming the buses could add time and cost.
Remember 6241only had white paint and the blue decal.  It also looks as though the black rubber was removed from the lower area of the sides of the bus.
Edited by artthouwill
Some other buses (6682 comes to mind, and I think a couple of other North buses) got the treatment of essentially a white bus with the current logo.
Saw 3 wrapped buses today on the south side:  6186, 6218, and 6179.  6186 looked by far the worst.  I didn't get a picture of it, but if you look at the front turn signals, they are not covered.  The other 2 buses didn't look like that.  It also looked in spots that the wrapping was coming off.  I wonder if this was one of the first buses that was wrapped when South first started doing it.
  • 6 months later...
55 minutes ago, jesi2282 said:
Introducing the new Wrigley Field Express wrap design. (Bus 6447)
I figured something was necessary after the 6000s were sent the showers by the ump.
More legible than prior versions. But what's that donut shaped thing under the batter's eye?xD
I wonder if there's a new six flags wrap? June is supposed to be the startup month.
I just saw a new Pace wrap in Skokie today around 5:30 PM. It read something about avoiding construction delays & take Pace. It came across the intersection too fast to get a photo & I couldn't follow it to try.
I might have seen the same at Golf Mill on bus 6450. It was by then too dark to make out fully, but there was a lot of automobiles  pattern on the side, and  a large pacebus.com and 847-364-PACE on the back.
Does it look something like this? I copied the image from this page.
As best as I can tell, yes, although it looked like several rows of cars. It was about 9:30 p,m. and pretty dark.
