artthouwill Posted December 30, 2018 Report Posted December 30, 2018 1 hour ago, NewFlyerMCI said: Right, forgot about that. While I admittedly don't know the logistics behind all the placements, it would honestly be better for GHo to stop at L or N. Better to take 95th & Halsted to 57 than backtrack to 87th or that terrible 95th, Michigan, 99th Pl, State maneuver, which still ended up backtracking. It really doesn't matter which terminal Greyhoud uses as neither affects routing to and from the station. While some trips will use 85th and Halsted to U - 57, trips going east have the option of going Marquette and State or 87th to the Skyway. Some may even go 95th, Ewing and Indianapolis Blvd to the IndianaToll Rd. Quote
NewFlyerMCI Posted December 30, 2018 Report Posted December 30, 2018 1 hour ago, artthouwill said: It really doesn't matter which terminal Greyhoud uses as neither affects routing to and from the station. While some trips will use 85th and Halsted to U - 57, trips going east have the option of going Marquette and State or 87th to the Skyway. Some may even go 95th, Ewing and Indianapolis Blvd to the IndianaToll Rd. My point wasn't with the skyway, that's fairly straightforward from the terminal. My point is (On I-57 routings) that only very few drivers use 95th & Halsted and instead prefer to backtrack all the way to 87th or 79th, which is a bit more time-consuming + that when terminals started shifting, some drivers didn't adhere and only picked up/dropped off in front of the station on 95th St, a trend I suspect will continue. The upcoming terminal placement will only exacerbate circuitous routings taken to get back to I-57. Also, Marquette & State? Quote
andrethebusman Posted December 31, 2018 Report Posted December 31, 2018 "Official" route to 57 is 95th-Halsted. To Indiana Tollway is Ryan to Marquette-State-Skyway. Inbound from Indiana is Skyway-87th-Ryan. However, a lot is left to driver discretion. Quote
artthouwill Posted December 31, 2018 Report Posted December 31, 2018 14 hours ago, NewFlyerMCI said: My point wasn't with the skyway, that's fairly straightforward from the terminal. My point is (On I-57 routings) that only very few drivers use 95th & Halsted and instead prefer to backtrack all the way to 87th or 79th, which is a bit more time-consuming + that when terminals started shifting, some drivers didn't adhere and only picked up/dropped off in front of the station on 95th St, a trend I suspect will continue. The upcoming terminal placement will only exacerbate circuitous routings taken to get back to I-57. Also, Marquette & State? That could be two things. First, if a driver is only dropping off at 95th en route to Chicago, it would be faster and easier to drop off on 95th rather than circle the entire south Terminal. The other might be driver unfamiliarity, especially if a non Chicago based driver who hasn't been here in awhile comes. As for Greyhound's east routing, the bus goes north on the Ryan to Marquette. At that exit, expressway traffic does not merge into State before the light like the other exits, but the Marquette exit traffic light is at Marquette. From there the bus can make a slight right on Marquette and an immediate left on northbound State to the next light to turn right to enter the Skyway. The only question is whether when the North Terminal construction is complete, will Greyhound be moved again? Quote
Tcmetro Posted January 5, 2019 Report Posted January 5, 2019 After visiting the new 95th terminal, it looks like the bays under construction (E, F, G) are destined for the #29-State bus. Quote
Busjack Posted January 5, 2019 Report Posted January 5, 2019 17 minutes ago, Tcmetro said: After visiting the new 95th terminal, it looks like the bays under construction (E, F, G) are destined for the #29-State bus. The question would then be how they get into them, unless they are reconstructing the entrance from Lafayette and exit to State. Quote
Tcmetro Posted January 5, 2019 Report Posted January 5, 2019 Yes, there will be an entrance to the north bus bridge from Lafayette and exit to State. Quote
Mr.cta85 Posted January 5, 2019 Report Posted January 5, 2019 2 hours ago, Busjack said: The question would then be how they get into them, unless they are reconstructing the entrance from Lafayette and exit to State. Yea they will, eventually the 29 will be relocated to its original spot once the terminal is fully completed. They told us this while they were showing operators the north terminal before it opened. 3 Quote
cta5658 Posted January 7, 2019 Report Posted January 7, 2019 Question, what is the train berthing method for terminating Red Line trains since the platform is longer? Quote
NewFlyerMCI Posted January 7, 2019 Report Posted January 7, 2019 5 hours ago, cta5658 said: Question, what is the train berthing method for terminating Red Line trains since the platform is longer? I imagine they pull up as much as possible towards the southern end. When I was there over the holidays, I entered through the South terminal, but the trains could still reach the exits for the North terminal, seeing as the Red Line runs pretty much only 8-car consists. The platform also didn't look that much longer, but I didn't have a whole bunch of time to explore before I had to get on the train. Someone more informed might be able to tell you better. Quote
Tcmetro Posted January 7, 2019 Report Posted January 7, 2019 I think the berthing is still the same. It ends up that the north stairs are close to the front of the train and the south stairs are close to the back of the train. Not sure if this will change, as the northern part of the platform is still under construction. Quote
BusHunter Posted January 7, 2019 Author Report Posted January 7, 2019 Was over there myself the station looks good. What a station. They have a tarp over the north entrance though. They need to work on that extension we aren't getting any younger here!!! So it doesn't look like they can berth 2 trains back to back. They should have made it like 54/cermak this way they could berth 4 trains you have the busiest line busiest station but no train capacity. Quote
Sam92 Posted January 7, 2019 Report Posted January 7, 2019 4 hours ago, BusHunter said: Was over there myself the station looks good. What a station. They have a tarp over the north entrance though. They need to work on that extension we aren't getting any younger here!!! So it doesn't look like they can berth 2 trains back to back. They should have made it like 54/cermak this way they could berth 4 trains you have the busiest line busiest station but no train capacity. Is that why the red line is still running some Ashland trips? Quote
BusHunter Posted January 7, 2019 Author Report Posted January 7, 2019 30 minutes ago, Sam92 said: Is that why the red line is still running some Ashland trips? Possibly. But more likely to keep out of the way of construction at 95th. Quote
NewFlyerMCI Posted January 8, 2019 Report Posted January 8, 2019 1 hour ago, Sam92 said: Is that why the red line is still running some Ashland trips? 1 hour ago, BusHunter said: Possibly. But more likely to keep out of the way of construction at 95th. Might be because of Garfield as well. While I was there, I took the 3 to Garfield green to catch the train whenever I needed the green and I noticed that while the workers are there, only 1 train is allowed in the station at once. A train coming in the opposite direction had to wait until the first one left, which I found strange since they were not single tracking. This only works if the red West 63rd trains taking the place of green West 63rd trains is reducing the overall number of trains going through Garfield, which I don't know for sure. Quote
Busjack Posted January 8, 2019 Report Posted January 8, 2019 7 minutes ago, NewFlyerMCI said: Might be because of Garfield as well. While I was there, I took the 3 to Garfield green to catch the train whenever I needed the green and I noticed that while the workers are there, only 1 train is allowed in the station at once. A train coming in the opposite direction had to wait until the first one left, which I found strange since they were not single tracking. This only works if the red West 63rd trains taking the place of green West 63rd trains is reducing the overall number of trains going through Garfield, which I don't know for sure. Doesn't make any sense. There are track restrictions on the Green Line, so run half the Red Line trains on it, too? Quote
artthouwill Posted January 8, 2019 Report Posted January 8, 2019 15 minutes ago, NewFlyerMCI said: Might be because of Garfield as well. While I was there, I took the 3 to Garfield green to catch the train whenever I needed the green and I noticed that while the workers are there, only 1 train is allowed in the station at once. A train coming in the opposite direction had to wait until the first one left, which I found strange since they were not single tracking. This only works if the red West 63rd trains taking the place of green West 63rd trains is reducing the overall number of trains going through Garfield, which I don't know for sure. The two are unrelated. The Ashland Red trips seem to be the result of the continuing construction at 95th. The Garfield Green Line station delays are the result of construction at that station. Unlike during the Red Line rebuild of 2013, Green Line Ashland/63 trips are still operating. Roughly the Ashland Reds are operating every 6 minutes which is slightly more frequent than the Green Line trains combined. 1 Quote
cta5658 Posted January 8, 2019 Report Posted January 8, 2019 On 1/5/2019 at 2:30 PM, Mr.cta85 said: Yea they will, eventually the 29 will be relocated to its original spot once the terminal is fully completed. They told us this while they were showing operators the north terminal before it opened. What will be in bus bays Z and Y when the 29 gets relocated to it's original spot? Quote
NewFlyerMCI Posted January 8, 2019 Report Posted January 8, 2019 21 minutes ago, cta5658 said: What will be in bus bays Z and Y when the 29 gets relocated to it's original spot? Probably layover and/or special service space (such as outside transit agencies or the brookfield zoo routes). Everything else is pretty much covered, unless they do some weird unexpected thing like extend the 3 or 24. Also possible the 100 and/or 359 get moved off the street. All speculation on my part. Quote
CircleSeven Posted February 22, 2019 Report Posted February 22, 2019 CTA has release modifications to the bus stops again at 95th & State, effective Sunday. I guess they're done with the construction at the north terminal. Some of the changes, the #29 returns to its original bus stop on the north bridge, but the Grayhound will stay at the south terminal. The #34/119 moves to the bays on the west side of the north terminal. The #108 & #352 moves to the east side of the terminal. 1 Quote
artthouwill Posted February 23, 2019 Report Posted February 23, 2019 3 hours ago, CircleSeven said: CTA has release modifications to the bus stops again at 95th & State, effective Sunday. I guess they're done with the construction at the north terminal. Some of the changes. the #29 returns to its original bus stop on the north bridge, but the Grayhound will stay at the south terminal. The #34/119 moves to the bays on the west side of the north terminal. The #108 & #352 moves to the east side of the terminal. At least for now, there seems to be no change concerning the Res Line trips to/from Ashland/63. Quote
Aiden Tabucic Posted February 23, 2019 Report Posted February 23, 2019 14 hours ago, artthouwill said: At least for now, there seems to be no change concerning the Res Line trips to/from Ashland/63. I have a feeling CTA is keeping the red line to Ashland/63rd Quote
Sam92 Posted February 23, 2019 Report Posted February 23, 2019 1 hour ago, Aiden Tabucic said: I have a feeling CTA is keeping the red line to Ashland/63rd There's still yard work to accommodate future extensions being done so there's still limited access to the yard that can't handle a train every 2 min Quote
Sam92 Posted February 23, 2019 Report Posted February 23, 2019 15 hours ago, artthouwill said: At least for now, there seems to be no change concerning the Res Line trips to/from Ashland/63. 19 hours ago, CircleSeven said: CTA has release modifications to the bus stops again at 95th & State, effective Sunday. I guess they're done with the construction at the north terminal. Some of the changes, the #29 returns to its original bus stop on the north bridge, but the Grayhound will stay at the south terminal. The #34/119 moves to the bays on the west side of the north terminal. The #108 & #352 moves to the east side of the terminal. Looks like they made it so buses can pull rightin and out faster vs having to wait through a left turn signal Quote
Aiden Tabucic Posted February 23, 2019 Report Posted February 23, 2019 2 minutes ago, Sam92 said: There's still yard work to accommodate future extensions being done so there's still limited access to the yard that can't handle a train every 2 min There’s the answer. Thank you @Sam92 Quote
