YoungBusLover Posted September 20, 2023 Report Posted September 20, 2023 Working Pulaski on the weekends I've seen a lot of operators take the entrance turning into the station pretty slow due to the uneven terrain of the pavement from the terminal to the actual street. I myself hate the uneven part of that entrance because the suspension and shocks will rock the bus back and forth if you don't enter at the right angle and if you're not careful the power steering will lock up on you for a split if you go in there to fast. Hence the 3-5 mph speed limit were suppose to take going in there. The Nova's handle the turn a bit better than the Flyers do and the turn radius on a lot of these flyers aren't what they use to be. All in all I just hope my fellow co-worker is ok because two have 20 passengers on board at that time of the morning to take that kind of a turn then impact into the pole like that will cause whiplash and aches and pains. 1 Quote
artthouwill Posted September 21, 2023 Report Posted September 21, 2023 2 hours ago, YoungBusLover said: Working Pulaski on the weekends I've seen a lot of operators take the entrance turning into the station pretty slow due to the uneven terrain of the pavement from the terminal to the actual street. I myself hate the uneven part of that entrance because the suspension and shocks will rock the bus back and forth if you don't enter at the right angle and if you're not careful the power steering will lock up on you for a split if you go in there to fast. Hence the 3-5 mph speed limit were suppose to take going in there. The Nova's handle the turn a bit better than the Flyers do and the turn radius on a lot of these flyers aren't what they use to be. All in all I just hope my fellow co-worker is ok because two have 20 passengers on board at that time of the morning to take that kind of a turn then impact into the pole like that will cause whiplash and aches and pains. Could it have been a driver that was unfamiliar with the situation there, either a rookie or a driver who rarely works that route by luck or transfer from another garage? It seems amazing that CTA either was unaware or negligent concerning the conditions at the station. From what I can see, it looks like it's all on CTA property. 1 Quote
Busjack Posted September 21, 2023 Report Posted September 21, 2023 36 minutes ago, artthouwill said: ... It seems amazing that CTA either was unaware or negligent concerning the conditions at the station. From what I can see, it looks like it's all on CTA property. It is, but the station has been there for 30 years, so it's difficult to say there is any inherent defect. The Law Dept. will eventually sort it out. Quote
YoungBusLover Posted September 21, 2023 Report Posted September 21, 2023 13 hours ago, artthouwill said: Could it have been a driver that was unfamiliar with the situation there, either a rookie or a driver who rarely works that route by luck or transfer from another garage? It seems amazing that CTA either was unaware or negligent concerning the conditions at the station. From what I can see, it looks like it's all on CTA property. Everything you said could very likely be a possibility but one thing is for certain, Operators should never go into a terminal/station with a turn radius that is meant to be taken slow and easy to begin with. Litigation will sort all of this out along with the HD (Hard Drive). It's a lose/lose situation because if the operator is at fault then we already know where that goes, if the equipment was defective prior the operator having the 10-71 and the operator was aware then that makes it even worse but if not and it was just a spare of the moment freakish accident then either way lawsuits will be in the future for CTA. 13 hours ago, Busjack said: It is, but the station has been there for 30 years, so it's difficult to say there is any inherent defect. The Law Dept. will eventually sort it out. The station is maintained fairly well being 30 year-old now, all of the Orange line stations could use a slight overhaul which is a long ways away from now. I do agree with you though in part saying "The Law Dept. will eventually sort it out." Quote
Busjack Posted September 21, 2023 Report Posted September 21, 2023 25 minutes ago, YoungBusLover said: The station is maintained fairly well being 30 year-old now, all of the Orange line stations could use a slight overhaul which is a long ways away from now. I do agree with you though in part saying "The Law Dept. will eventually sort it out." The only reason I mentioned the 30 years, was that if buses were hitting that support column on a regular basis, CTA would be on notice of a defect, but if this is the first time in 30 years, it wouldn't, and, as @artthouwill used the word "negligent," my thoughts tended in the direction that negligence involves notice. But not being in a position to come to a conclusion, we agreed that was for the Law Dept. 1 Quote
YoungBusLover Posted September 21, 2023 Report Posted September 21, 2023 11 minutes ago, Busjack said: The only reason I mentioned the 30 years, was that if buses were hitting that support column on a regular basis, CTA would be on notice of a defect, but if this is the first time in 30 years, it wouldn't, and, as @artthouwill used the word "negligent," my thoughts tended in the direction that negligence involves notice. But not being in a position to come to a conclusion, we agreed that was for the Law Dept. Oh I see, thank you for that clarification. ? Quote
Shannoncvpi Posted September 22, 2023 Report Posted September 22, 2023 On 9/20/2023 at 3:26 PM, Mr.NewFlyer1279 said: it’s a 50/50 chance Yea it is since it's a 07 model it's past it's 12 years & new buses then came in they might just do like how their doing 1447 just use it for parts Quote
Rhys Pate Posted November 21, 2023 Report Posted November 21, 2023 The L car pair involved in the recent Yellow Line accident was 5599-5600. 5599 is severely damaged in the front, as it was the car in front (thus, it hit the snow machine). Do you think 5599 is fixable, or will 5599 will be retired? The Yellow Line is suspended until further notice due to the accident. Quote
Busjack Posted November 21, 2023 Report Posted November 21, 2023 1 hour ago, Rhys Pate said: The L car pair involved in the recent Yellow Line accident was 5599-5600. 5599 is severely damaged in the front, as it was the car in front (thus, it hit the snow machine). Do you think 5599 is fixable, or will 5599 will be retired? The Yellow Line is suspended until further notice due to the accident. To repeat there is a topic on this specific accident, with more details, so why scatter the discussion all over the place? Quote
YoungBusLover Posted January 2, 2024 Report Posted January 2, 2024 Car versus Bus never ends well..... Accident occurred at Damen and Washington. Quote
Erin Mishkin Jr. Posted January 2, 2024 Report Posted January 2, 2024 1 hour ago, YoungBusLover said: Car versus Bus never ends well..... Accident occurred at Damen and Washington. end of the road for 1865 Quote
Busjack Posted January 2, 2024 Report Posted January 2, 2024 3 hours ago, YoungBusLover said: Car versus Bus never ends well..... Accident occurred at Damen and Washington. Was it the one in this article? Looks like it. Quote
Shannoncvpi Posted January 2, 2024 Report Posted January 2, 2024 12 hours ago, YoungBusLover said: Car versus Bus never ends well..... Accident occurred at Damen and Washington. Sadly 1865 may get retired since it's already up in age & depends on the rust it don't look like it's damaged that back but can't see the other side Quote
YoungBusLover Posted January 2, 2024 Report Posted January 2, 2024 10 hours ago, Busjack said: Was it the one in this article? Looks like it. Yessir, the driver of the auto ran a red light and the rest is history. 1 Quote
artthouwill Posted January 2, 2024 Report Posted January 2, 2024 13 hours ago, Busjack said: Was it the one in this article? Looks like it. Does anyone proofread anymore? The article claims that the accident happened in the 2200 black of West Washington, but it also said the bus was traveling southbound on Damen when it was struck. Either it was a typo or someone isn't familiar with Chicago. Quote
Busjack Posted January 3, 2024 Report Posted January 3, 2024 6 hours ago, artthouwill said: Does anyone proofread anymore? The article claims that the accident happened in the 2200 black of West Washington, but it also said the bus was traveling southbound on Damen when it was struck. Either it was a typo or someone isn't familiar with Chicago. I saw that, but initially thought it was not worth comment. Quote
Bus1883 Posted January 9, 2024 Report Posted January 9, 2024 On 1/2/2024 at 8:17 AM, Shannoncvpi said: Sadly 1865 may get retired since it's already up in age & depends on the rust it don't look like it's damaged that back but can't see the other side Yep with 70% of the options 3 and 4 in the boneyard I doubt it comes back. Quote
Shannoncvpi Posted January 9, 2024 Report Posted January 9, 2024 3 hours ago, Bus1883 said: Yep with 70% of the options 3 and 4 in the boneyard I doubt it comes back. Yea that's what's mostly down I see from crashes to rust Quote
Busjack Posted March 30, 2024 Report Posted March 30, 2024 Accident at 79th and Cottage Grove involved 7950 (ABC7). Quote
busfan2847 Posted March 30, 2024 Report Posted March 30, 2024 On 1/2/2024 at 8:17 AM, Shannoncvpi said: Sadly 1865 may get retired since it's already up in age & depends on the rust it don't look like it's damaged that back but can't see the other side According to maths22 1865 is back in service from 3/24 Quote
Shannoncvpi Posted March 30, 2024 Report Posted March 30, 2024 4 hours ago, busfan2847 said: According to maths22 1865 is back in service from 3/24 Dam I thought it would have been retired Quote
artthouwill Posted June 10, 2024 Report Posted June 10, 2024 Apparently there's an accident involving a CTA bus hitting several cars at 35th and Halsted. Quote
YoungBusLover Posted June 10, 2024 Report Posted June 10, 2024 58 minutes ago, artthouwill said: Apparently there's an accident involving a CTA bus hitting several cars at 35th and Halsted. I pray for a speedy recovery to everyone involved, the operator from what I heard had a medical emergency as the damage path spans from 36th to 34th. Apparently the bus ran into the side of a newly renovated theatre along with parked cars and cars traveling through the intersection at 35th and Halsted. fAjTNi9YlkjbCWTt.mp4 An-pVJqY61jVoLf8eb-E8s5m1mSZxTW4L97Pm0YfVSZWXRuf3WlzLDgji4BqC0_MyMSJHPJHrAo3_iU2tVHS8liG.mp4 FiVGfH9TNyDh-b1e.mp4 Quote
ajm522 Posted July 20, 2024 Report Posted July 20, 2024 I would expect 8594 to be LTO as it was involved in a crash this morning. Quote
