MetroShadow Posted September 13, 2019 Report Posted September 13, 2019 On 9/9/2019 at 2:06 PM, NewFlyerMCI said: What possible reason for a year long delay? My first guess was Edens BOS but they could either scrap that or move the 54A/641 to phase 3 Considering a major service change can happen during any given cycle, it might be better to wait until August 2020 anyway. Usually it’s equipment, driver availability, and/or construction with bays. 1 Quote
BusHunter Posted September 13, 2019 Report Posted September 13, 2019 Probably they are trying to figure out where to put #215 and #641 at jeff. They already have 270 and Pulse to contend with. Quote
NewFlyerMCI Posted September 13, 2019 Report Posted September 13, 2019 2 hours ago, BusHunter said: Probably they are trying to figure out where to put #215 and #641 at jeff. They already have 270 and Pulse to contend with. That seems fairly simple. 85 doubles up since it's a thru route, 215 shares with 225/226, since both of these routes combined still have like a 60 min frequency and if you correctly stagger them, 641 can share with 85A, since they have the same frequency Quote
artthouwill Posted September 13, 2019 Report Posted September 13, 2019 8 hours ago, NewFlyerMCI said: That seems fairly simple. 85 doubles up since it's a thru route, 215 shares with 225/226, since both of these routes combined still have like a 60 min frequency and if you correctly stagger them, 641 can share with 85A, since they have the same frequency Under Phase 2, doesn't the 226 get rerouted to serve Howard Red Line? That would mean that it would no longer serve Jefferson Park. Quote
MetroShadow Posted September 14, 2019 Report Posted September 14, 2019 4 hours ago, artthouwill said: Under Phase 2, doesn't the 226 get rerouted to serve Howard Red Line? That would mean that it would no longer serve Jefferson Park. Delete 226. Add 215 and 641. And increase frequency on 225. CTA will need to give up some bays. Quote
Sam92 Posted September 14, 2019 Report Posted September 14, 2019 45 minutes ago, MetroShadow said: Delete 226. Add 215 and 641. And increase frequency on 225. CTA will need to give up some bays. You'd think the expansion would have accounted for that ?? Quote
NewFlyerMCI Posted September 14, 2019 Report Posted September 14, 2019 21 hours ago, artthouwill said: Under Phase 2, doesn't the 226 get rerouted to serve Howard Red Line? That would mean that it would no longer serve Jefferson Park. 16 hours ago, MetroShadow said: Delete 226. Add 215 and 641. And increase frequency on 225. CTA will need to give up some bays. 15 hours ago, Sam92 said: You'd think the expansion would have accounted for that ?? So if the 85 is combined, that's one free one right there that the 215 could take. 641 could share with either 215 or 225, and since the route is short enough, the actually layover can take place at county courthouse. Everything just barely fits. Alternatively, 641 could also share with 85A, since both routes could be staggered to not interfere with each other that much Quote
BusHunter Posted September 16, 2019 Report Posted September 16, 2019 #215 probably needs it's own bay. I think theres an open bay in the south terminal still something could go over there like the 85A. If cta were smart they could stagger the times of the 85a and 88 to run 10 minutes apart between the two they could share a bay. I dont know about cta and pace sharing a bay. You can argue 56A and #270 did it but they were similar routes. Unless you put 225 with 85A but what about 641? Regardless the north terminal is probably going to soon be the Pace terminal. Maybe #92 and #85 stays but that's about it. Btw, was wondering what #270 does when Pulse is always filling its bay? Drove past. The operators was using 226s bay. So what do they do in the rush hour? Quote
Mr.NewFlyer1051 Posted September 26, 2019 Report Posted September 26, 2019 On 9/16/2019 at 1:00 PM, BusHunter said: #215 probably needs it's own bay. I think theres an open bay in the south terminal still something could go over there like the 85A. If cta were smart they could stagger the times of the 85a and 88 to run 10 minutes apart between the two they could share a bay. I dont know about cta and pace sharing a bay. You can argue 56A and #270 did it but they were similar routes. Unless you put 225 with 85A but what about 641? Regardless the north terminal is probably going to soon be the Pace terminal. Maybe #92 and #85 stays but that's about it. Btw, was wondering what #270 does when Pulse is always filling its bay? Drove past. The operators was using 226s bay. So what do they do in the rush hour? There are 2 open bays one next to 85A and one next to 88 (Stop P) and (Stop G) Quote
NewFlyerMCI Posted September 26, 2019 Report Posted September 26, 2019 9 hours ago, Mr.NewFlyer1051 said: There are 2 open bays one next to 85A and one next to 88 (Stop P) and (Stop G) Do you have the schematic of where routes are assigned? Or do you know where to find it? Quote
Mr.NewFlyer1051 Posted September 26, 2019 Report Posted September 26, 2019 2 hours ago, NewFlyerMCI said: Do you have the schematic of where routes are assigned? Or do you know where to find it? Find what? The bays? Quote
chicagocubs6323 Posted September 26, 2019 Report Posted September 26, 2019 4 hours ago, NewFlyerMCI said: Do you have the schematic of where routes are assigned? Or do you know where to find it? He has no proof, he's just guessing. Quote
NewFlyerMCI Posted September 26, 2019 Report Posted September 26, 2019 3 hours ago, Mr.NewFlyer1051 said: Find what? The bays? Yes 1 hour ago, chicagocubs6323 said: He has no proof, he's just guessing. Actually, not sure that's the case here. I saw a diagram (which is what I'm trying to find again) of the assigned bays for Jeff Pk during the construction, but I was fairly certain there was at 1 free bay per side not currently utilized by any route. However, it's been such a long time since I saw the schematic that I didn't want to say just anything without looking at it once more. 1 Quote
Mr.NewFlyer1051 Posted September 27, 2019 Report Posted September 27, 2019 6 hours ago, chicagocubs6323 said: He has no proof, he's just guessing. I live right next to the Jefferson park center what are you talking about????? Quote
chicagocubs6323 Posted September 27, 2019 Report Posted September 27, 2019 3 hours ago, Mr.NewFlyer1051 said: I live right next to the Jefferson park center what are you talking about????? False info with nothing to prove it. Quote
Mr.NewFlyer1051 Posted September 27, 2019 Report Posted September 27, 2019 7 hours ago, chicagocubs6323 said: False info with nothing to prove it. Ok yea totally I’m making wrong info Quote
CircleSeven Posted January 11, 2020 Report Posted January 11, 2020 Follow up. Pace has posted this flyer for public hearings regarding Phase 2 changes. And because of "resource constraints", the proposed changes are different from the original changes: From Jefferson Park, the #215 will go straight down Foster to Pulaski, instead of Foster-Cicero-Peterson-Pulaski. The proposed #641 is not included in these new changes. That probably means #54A is saved from the blade. For the first time in over a decade, the #226 will go straight down Oakton between Mannheim and Busse, instead of serving the Des Plaines Metra. The bus will also turn on Skokie to Howard instead of Crawford, eliminating duplication of the #97 on that one-mile stretch of Oakton. The #423 will terminate at the Glen of North Glenview Metra station via Waukegan and Willow Roads, but it will still serve Glenview Metra via Waukegan-Dewes-Harlem-Glenview and then back on Waukegan. The #422 will only terminate at the Glenview Metra, and will NOT proceed north to the Glen Metra station, as it was originally proposed. The new #424 will only terminate at the Glen Metra, and will NOT proceed north on Shermer & Waukegan to Northbrook Court as it was originally proposed. Quote
CircleSeven Posted January 30, 2020 Report Posted January 30, 2020 Ahead of the public hearings (which the first one will be tonight), Pace has posted PDFs of changes to each bus route individually. #215, #225, #226, #422, #423, #424 and the discoutinued #210 & #421. And here's the map that serves the schools. Speaking of school trips, the #422 will add a school trip to Glenbrook South HS, using a portion of the #210 routing from downtown Glenview. Quote
NewFlyerMCI Posted January 30, 2020 Report Posted January 30, 2020 1 hour ago, CircleSeven said: Ahead of the public hearings (which the first one will be tonight), Pace has posted PDFs of changes to each bus route individually. #215, #225, #226, #422, #423, #424 and the discoutinued #210 & #421. And here's the map that serves the schools. Speaking of school trips, the #422 will add a school trip to Glenbrook South HS, using a portion of the #210 routing from downtown Glenview. 210 has been on it's last legs for a minute, so this isn't surprising I'll say again removing the Des Plaines service from the 226 does more harm than good. Good to see they're breaking up the 423 Quote
MetroShadow Posted February 7, 2020 Report Posted February 7, 2020 On 1/30/2020 at 10:15 AM, NewFlyerMCI said: 210 has been on it's last legs for a minute, so this isn't surprising I'll say again removing the Des Plaines service from the 226 does more harm than good. Good to see they're breaking up the 423 My only comment is the 226: it's a grid route and sending it to DP, while I can see why, you've got the 250 and Dee Road Metra for connections. Plus not every bus is going west of Milwaukee. Perhaps the bulk of the passengers don't need DP to connect. 1 Quote
artthouwill Posted February 7, 2020 Report Posted February 7, 2020 I hadn't been out there in awhile. Took a look yesterday and was surprised. The 221, which uses to run from Rosemont CTA via River Rd, Devon, Higgins, Manheim, and Touhy to Wolf, now runs River Rd and Touhy. The 250, which replaced the 220 that ran Manhein to Lee, now runs Manheim, Touhy, Lee. The 230 runs River Rd and Touhy. The 422 definitely needed to be broken up. Hopefully I will get up that way again soon. Quote
TransitXan17 Posted June 7, 2020 Report Posted June 7, 2020 (edited) Don’t know if this has been addressed on this thread or not, but is there a reason why Route 423 shifts from Harlem Ave to Waukegan Road at Dempster St? I’m curious about what benefits the new service would have along Waukegan Road as opposed to the current Harlem Ave corridor. https://pacebus.com/pdf/initiatives/NSCP/423.pdf Edit: I understand part of the reason why it’s rerouted is to provide service that Route 210 would no longer provide. Am I correct to assume there’s more ridership along this corridor? Edited June 8, 2020 by TransitXan17 Clarification Quote
BusHunter Posted June 8, 2020 Report Posted June 8, 2020 1 hour ago, TransitXan17 said: Don’t know if this has been addressed on this thread or not, but is there a reason why Route 423 shifts from Harlem Ave to Waukegan Road at Dempster St? I’m curious about what benefits the new service would have along Waukegan Road as opposed to the current Harlem Ave corridor. https://pacebus.com/pdf/initiatives/NSCP/423.pdf Edit: I understand part of the reason why it’s rerouted is to provide service that Route 210 would no longer provide. Am I correct to assume there’s more ridership along this corridor? Maybe it's just easier logistically to get the #423 to the Glen shopping area. By the time it stops and goes around the block it wastes more time. Now it can directly go. Or it could be the draw at Golf Metra!! Not!!? Quote
Busjack Posted January 16, 2022 Author Report Posted January 16, 2022 13 minutes ago, Mr.NewFlyer1051 said: what ever happened to the north shore coordination plan wit CTA? It hit a roadblock when multiple politicians protested the second stage plan to cut all service north and west of Glen Metra. Then COVID-19 hit. I was told by Driving Innovation: Quote In relation to Driving Innovation plan, initiative #A-5 proposes Pace conduct a system-wide assessment of its entire bus network. As part of this effort, any fixed-route, On Demand, or similar demand-response type services may be considered for these specific areas. It is also possible for part or all of the outstanding proposed North Shore changes to be reevaluated during this process. The A-5 initiative is currently anticipated to start sometime in 2022 and will include an extensive public outreach process among all impacted communities. Additionally, the Phase 2 changes will be subject to continued assessment of the post-pandemic demand for bus service, further coordination with the CTA, public hearings, and approval by Pace’s Board of Directors. 1 1 Quote
artthouwill Posted January 16, 2022 Report Posted January 16, 2022 2 hours ago, Busjack said: It hit a roadblock when multiple politicians protested the second stage plan to cut all service north and west of Glen Metra. Then COVID-19 hit. I was told by Driving Innovation: Welcome back. You have been sorely missed. 3 Quote
