BusHunter Posted September 11, 2016 Author Report Posted September 11, 2016 7 minutes ago, Busjack said: No, it couldn't be. The specs for the 1000s was for 1029 buses and the question was "why one short?", and the answer was 1005 was done. This requisition is for 208 buses, not 207. Well we could argue #1305 was left out in the cold Quote
Busjack Posted September 11, 2016 Report Posted September 11, 2016 6 minutes ago, BusHunter said: Well we could argue #1305 was left out in the cold Do I have to get flamed for another "go back and look at the posts" "or use the search function"? Like it finding your post here? Quote
andrethebusman Posted September 12, 2016 Report Posted September 12, 2016 1005 we can safely say was the pilot for the rehab job, to see what it actually would entail before series production began. Normal practice, just in case there are any "surprises", they can be dealt with before 1029 of something is ordered that will not work. If the 4000-4207 job is "turnkey" by definition it means an outside general contractor who would then be fully responsible for rounding up any subcontractors, parts, etc. CTA sends unrehabbed bus to contractor, gets fully completed, ready to roll bus back. This is how the 2200's were handled by Alstom. Quote
geneking7320 Posted September 12, 2016 Report Posted September 12, 2016 I'll admit to being too lazy to search out the specs. Will buses > 4150 retain all the aisle facing seats? 1 Quote
ChicagoNova Posted September 12, 2016 Report Posted September 12, 2016 5 hours ago, andrethebusman said: This is how the 2200's were handled by Alstom. 2600's actually. Quote
jajuan Posted September 12, 2016 Report Posted September 12, 2016 16 hours ago, BusHunter said: And what is your source. They looked pretty updated to me. And where's your source that they were rehabbed? The source that indicates that that was not a rehab on the MAN 4000s and simply a new paint job was CTA itself when it explicitly stated the midlife rehabs of the 4400s to extend their operable service lives were the first time they've done such a procedure for any bus model. Quote
Busjack Posted September 12, 2016 Report Posted September 12, 2016 7 hours ago, geneking7320 said: I'll admit to being too lazy to search out the specs. Will buses > 4150 retain all the aisle facing seats? Did anyone change any of the seats in the 1000s? Basically, they don't affect whether a bus can go 500,000 miles. Quote
Sam92 Posted September 12, 2016 Report Posted September 12, 2016 Welp at least after the rehabs the 4000 assignments should become a bit more organized. They kinda scattered once the 4300s and Chicago garage came into the picture as far as artic assignments Quote
Busjack Posted September 12, 2016 Report Posted September 12, 2016 57 minutes ago, Sam92 said: Welp at least after the rehabs the 4000 assignments should become a bit more organized. They kinda scattered once the 4300s and Chicago garage came into the picture as far as artic assignments Probably still depends on whether there are dedicated Jump buses. 1 Quote
andrethebusman Posted September 13, 2016 Report Posted September 13, 2016 On 9/12/2016 at 5:28 AM, ChicagoNova said: 2600's actually. 2200's were "rebuilt" to a much greater extent than 2600's were. Who did them, MK? MK did some really good work rebuilding several New York subway car series. Too bad they bit off more than they could chew and went bust over it. Quote
Busjack Posted September 13, 2016 Report Posted September 13, 2016 1 hour ago, andrethebusman said: MK Yes, No. See below. Quote
andrethebusman Posted September 13, 2016 Report Posted September 13, 2016 MK did a really nice job on the 2200's - new interiors, new ac. From pretty mediocre cars they became really nice cars. The 2600's you could only tell if it was rehabbed by looking for the Alstom plate. 1000's are starting to show their age again. Many transmissions are starting to grind again, ac failures are starting to show. Many small things associated with an old bus. Quote
Busjack Posted September 13, 2016 Report Posted September 13, 2016 1 minute ago, andrethebusman said: . The 2600's you could only tell if it was rehabbed by looking for the Alstom plate. There was other stuff, such as that the conductor position door controls were taken out, but the wall lining seemed to be replaced instead of patched. The question also is whether the full width cab partition was added at that time. Quote
jajuan Posted September 13, 2016 Report Posted September 13, 2016 18 minutes ago, Busjack said: There was other stuff, such as that the conductor position door controls were taken out, but the wall lining seemed to be replaced instead of patched. The question also is whether the full width cab partition was added at that time. And don't forget the most obvious indicator to add to your point that Andre is understating some things, going from charcoal gray trim windows and thin red, white and blue striping to the current all silver body. That big change to the exterior is what made you look for the other work in the rehabs. 1 Quote
Busjack Posted September 13, 2016 Report Posted September 13, 2016 9 minutes ago, jajuan said: And don't forget the most obvious indicator to add to your point that Andre is understating some things, going from charcoal gray trim windows and thin red, white and blue striping to the current all silver body. That big change to the exterior is what made you look for the other work in the rehabs. Which, in fact made them more noticeable, as the only things really noticeable on a 2200 (other than the NY Rali Car placard) were the hopper windows and that the seats were swapped from bench to plastic shell. In which case, I have to retract the MK. I got it confused with the single unit car rehabs. Chicago-l.org source on the 2200s. Quote
andrethebusman Posted September 13, 2016 Report Posted September 13, 2016 2 hours ago, Busjack said: There was other stuff, such as that the conductor position door controls were taken out, but the wall lining seemed to be replaced instead of patched. The question also is whether the full width cab partition was added at that time. The conversion to one-person -operation was completely separate. Wasn't all done at the same time, if I remember. First they installed the extra door controls at the cab end, and had a yellow strap across the front, then later the conductor end controls were removed and full width cab wall installed after the "subway conductors" were eliminated. 1 Quote
Master58 Posted October 15, 2016 Report Posted October 15, 2016 Does anyone know when the rehabs on the 4000's are suppose to start I heard it was sometime in early 2017 and have they even decided which contractor is going to work on the rehabs? Quote
BusHunter Posted October 15, 2016 Author Report Posted October 15, 2016 2 hours ago, Master58 said: Does anyone know when the rehabs on the 4000's are suppose to start I heard it was sometime in early 2017 and have they even decided which contractor is going to work on the rehabs? Did anyone discover what was the deal with #4099, the one jump bus retrofitted with new led lighting inside? i forgot all about it. Quote
Busjack Posted October 15, 2016 Report Posted October 15, 2016 3 hours ago, Master58 said: Does anyone know when the rehabs on the 4000's are suppose to start I heard it was sometime in early 2017 and have they even decided which contractor is going to work on the rehabs? It's still on the Contract Opportunities page with a bid due date of 10/28/2016, so it isn't yet. Quote
busfan2847 Posted December 31, 2016 Report Posted December 31, 2016 Using Maths 22 tracker I have been monitoring buses in service since 2/1/2016 three times a week at 8am and 4pm (usually MWF). These are the 4000 that have not been recorded in service, in the last two months (dates in brackets are the last time I have records of them being out): 4015 (10/16), 4042 (7/16), 4074 (10/16), 4078 (7/16), 4102 (5/16), 4116 (9/16), 4118 (9/16), 4137 (out all year), 4156 (7/16), 4174 (10/16), 4185 (2/16), 4189 (10/16), 4194 (8/16) and 4201 (9/16) For the 4300s there are 4300 (Chicago trainer was last recorded location?), 4338 (10/16) This does not include 4167, 4323 and 4332 reported withdrawn. All other 4000/4300 have been in service on bus tracker since 28th October 2016. 1 Quote
jajuan Posted January 1, 2017 Report Posted January 1, 2017 16 hours ago, busfan2847 said: Using Maths 22 tracker I have been monitoring buses in service since 2/1/2016 three times a week at 8am and 4pm (usually MWF). These are the 4000 that have not been recorded in service, in the last two months (dates in brackets are the last time I have records of them being out): 4015 (10/16), 4042 (7/16), 4074 (10/16), 4078 (7/16), 4102 (5/16), 4116 (9/16), 4118 (9/16), 4137 (out all year), 4156 (7/16), 4174 (10/16), 4185 (2/16), 4189 (10/16), 4194 (8/16) and 4201 (9/16) For the 4300s there are 4300 (Chicago trainer was last recorded location?), 4338 (10/16) This does not include 4167, 4323 and 4332 reported withdrawn. All other 4000/4300 have been in service on bus tracker since 28th October 2016. Hmm these artics are from all four garages (that were artic garages at the last time these were noted in service. Each garage's shortage from these sidelines appear to have been 4 artics per garage. The line of artics that folks reported seeing at South Shops then were not all from 103rd, but from all garages that had them. So basically based on this, there appears to be confirmation of my prior hypothesis that 103rd's troubles were from artics being down at the same time for short term maintenance rather than long term as this confirms analysis of the tracker showing 103rd's rush hour artic usage averaged roughly a 4 to 5 bus drop during late fall compared to that of summer. Given observations that Kedzie, North Park, and 103rd's artic usage hasn't changed much beyond what their normal average artic use tended to be before the Chicago artic purge, 103rd's artic gain basically served to plug the hole. Quote
busfan2847 Posted January 29, 2017 Report Posted January 29, 2017 4102 which has been out of service since May 2015 was out on the J14 both morning and afternoon rush hours on Friday. Quote
strictures Posted January 29, 2017 Report Posted January 29, 2017 On 10/15/2016 at 1:47 PM, Master58 said: Does anyone know when the rehabs on the 4000's are suppose to start I heard it was sometime in early 2017 and have they even decided which contractor is going to work on the rehabs? I was on a 4000 [don't remember the number, but it was a 22] at the end of December, which had all new seats, but they were still in the same wretched sideways layout. The tall metal framed seats with the weird backs had been replaced with blue plastic seats with shorter backs. Quote
RJL6000 Posted January 29, 2017 Report Posted January 29, 2017 1 hour ago, strictures said: I was on a 4000 [don't remember the number, but it was a 22] at the end of December, which had all new seats, but they were still in the same wretched sideways layout. The tall metal framed seats with the weird backs had been replaced with blue plastic seats with shorter backs. Could this be a replacement of the 4One Aries seats with the AMSECO InSight seats? Or (choke) AMSECO 6468 seats? Quote
Sam92 Posted January 29, 2017 Report Posted January 29, 2017 (edited) 3 hours ago, strictures said: I was on a 4000 [don't remember the number, but it was a 22] at the end of December, which had all new seats, but they were still in the same wretched sideways layout. The tall metal framed seats with the weird backs had been replaced with blue plastic seats with shorter backs. So you're saying it had the seats of a 4000 but arranged like a 4150? Did it have new lights as well cause 4099 from 103rd has new lights already Edited January 29, 2017 by Sam92 Quote
