briman94 Posted June 5, 2015 Author Report Posted June 5, 2015 Something shiny, something new... Quote
garmon757 Posted June 7, 2015 Report Posted June 7, 2015 Something shiny, something new... I'm surprised that you didn't use the signals the be under the tunnels i.e. the tunnel by London Kings Cross Station, tunnels between London-Victoria and Brighton, tunnels between Faversham, Gillingham, and Ebbsfleet. Quote
Busjack Posted June 7, 2015 Report Posted June 7, 2015 I'm surprised that you didn't use the signals the be under the tunnels i.e. the tunnel by London Kings Cross Station, tunnels between London-Victoria and Brighton, tunnels between Faversham, Gillingham, and Ebbsfleet.The real question is whether they have "RED OVER RED STOP AND STAY." Quote
MetroShadow Posted June 7, 2015 Report Posted June 7, 2015 What happens when you get bored and can't find any more ways to procrastinate on homework? You end up driving a 32-car 5000-series train through the Loop, that's what! It derailed at the end because there was so much momentum that even going a mere 20MPH was enough to throw the whole thing over the edge. See the description of the video for more info.I needed the LOL today. 1 Quote
briman94 Posted June 7, 2015 Author Report Posted June 7, 2015 I'm surprised that you didn't use the signals the be under the tunnels i.e. the tunnel by London Kings Cross Station, tunnels between London-Victoria and Brighton, tunnels between Faversham, Gillingham, and Ebbsfleet.I don't think they have the right signal aspects. The CTA has fairly unique diverging aspects so I decided to just make my own signals. I need to figure out what the 3-lens and 4-lens signals do too. Quote
garmon757 Posted June 7, 2015 Report Posted June 7, 2015 (edited) The real question is whether they have "RED OVER RED STOP AND STAY."I don't think they have the right signal aspects. The CTA has fairly unique diverging aspects so I decided to just make my own signals. I need to figure out what the 3-lens and 4-lens signals do too.Nope, not at all Busjack. Brian, the 4-lens signals represents the switch tracks and interlocks that have green signal on top, red as the second signal, yellow as third, and another red on the bottom. They're at all interlocks on the 95th branch, Congress Branch except Forest Park, some on the North Main Line between Armitage and Belmont, Paulina Junction, Douglas Branch, etc. This should help if you ever have reconsideration about them. Edited June 7, 2015 by garmon757 Quote
TheBrunswickBowler Posted June 7, 2015 Report Posted June 7, 2015 When do you think you will add the Marking Lights onto the trains? Quote
briman94 Posted June 7, 2015 Author Report Posted June 7, 2015 When do you think you will add the Marking Lights onto the trains?Probably after finals week (this week). Nope, not at all Busjack. Brian, the 4-lens signals represents the switch tracks and interlocks that have green signal on top, red as the second signal, yellow as third, and another red on the bottom. They're at all interlocks on the 95th branch, Congress Branch except Forest Park, some on the North Main Line between Armitage and Belmont, Paulina Junction, Douglas Branch, etc. This should help if you ever have reconsideration about them.When do the different colors light up? Mainline is something over red, diverging is red over something, blocked is red over red. Do diverging paths have a "clear" aspect at all, or are they always at caution? Quote
garmon757 Posted June 7, 2015 Report Posted June 7, 2015 (edited) Probably after finals week (this week). When do the different colors light up? Mainline is something over red, diverging is red over something, blocked is red over red. Do diverging paths have a "clear" aspect at all, or are they always at caution?Most signals on the Main Line are always cautious - yellow. (Signal is Red 1st row - Yellow 2nd row - blank 3rd row). When it comes to switching to another track its (Blank 1 row - Yellow 2nd row - Red 3rd row). The signals with the green signal (like the one in the photo) are always green with no red signals lighting up until a train surpass it causing it to change to double red signals. It's rare to see the white signal unless there's an override. Edited June 7, 2015 by garmon757 Quote
Busjack Posted June 7, 2015 Report Posted June 7, 2015 ....When do the different colors light up? Mainline is something over red, diverging is red over something, blocked is red over red. Do diverging paths have a "clear" aspect at all, or are they always at caution?chicago-l.org has this explanation. The only thing I know is the sign under a signal cluster such as what Garmon posted (but apparently not that one). 1 Quote
briman94 Posted June 10, 2015 Author Report Posted June 10, 2015 Guess what I finally started modelling... 1 Quote
briman94 Posted June 10, 2015 Author Report Posted June 10, 2015 Also, here's a random video of emergency brake testing. No wheels yet, but the bogies are at least there and functional... 1 Quote
MTRSP1900-CTA3200 Posted June 10, 2015 Report Posted June 10, 2015 Guess what I finally started modelling... Nice! I like the detail on the trolley block. Are you going to smooth out the third rail shoe connector eventually? 1 Quote
briman94 Posted June 10, 2015 Author Report Posted June 10, 2015 Nice! I like the detail on the trolley block. Are you going to smooth out the third rail shoe connector eventually?I might add some rounded corners, but I can do a lot just with textures. It's a relatively small part of the train that usually won't be seen up close, so having a lot of detail on it could impact performance, so most detail will be in the textures themselves. Quote
MTRSP1900-CTA3200 Posted June 10, 2015 Report Posted June 10, 2015 I might add some rounded corners, but I can do a lot just with textures. It's a relatively small part of the train that usually won't be seen up close, so having a lot of detail on it could impact performance, so most detail will be in the textures themselves.Oh OK. It's already better than the third rail equipment officially published on Steam anyways. 1 Quote
briman94 Posted June 11, 2015 Author Report Posted June 11, 2015 Build 15 of the CTA is live: http://briman0094.com/rw_buildThe entire brown line is complete with all stations from Kimball to the loop on the new route (the one just called "CTA"). Quote
TheBrunswickBowler Posted June 18, 2015 Report Posted June 18, 2015 Hey Briman, I played your CTA route for the first time today, and holy crap I was blown away! Amazing job! What else have you been working on? Any new line projects? Quote
briman94 Posted June 18, 2015 Author Report Posted June 18, 2015 Hey Briman, I played your CTA route for the first time today, and holy crap I was blown away! Amazing job! What else have you been working on? Any new line projects?Thanks! I'm mainly working on the scenery aspect of stuff right now. I have the entire new version of the Brown Line done, on the version of the route just called "CTA." Once I get the signals looking right and working correctly I'm going to redo the Orange Line in the new route. Quote
BusHunter Posted June 18, 2015 Report Posted June 18, 2015 I was wondering. It says at the start to set your signs before you depart the terminal. Can you set the signs yourself and if so, how? I seem to have forgot how to do it. Or is this getting implemented in a future build? Quote
briman94 Posted June 18, 2015 Author Report Posted June 18, 2015 I was wondering. It says at the start to set your signs before you depart the terminal. Can you set the signs yourself and if so, how? I seem to have forgot how to do it. Or is this getting implemented in a future build?The newest scenario sets the signs for you, but yes, you can change them yourself. If you press J it will cycle forwards and Shift + J will cycle backwards through the available signs. Quote
MetroShadow Posted June 23, 2015 Report Posted June 23, 2015 Forgive me for my ignorance on the subject (grad school does that), but does the program work on Steam (and if there is a workaround)? Quote
briman94 Posted June 23, 2015 Author Report Posted June 23, 2015 Forgive me for my ignorance on the subject (grad school does that), but does the program work on Steam (and if there is a workaround)?Yeah, Train Simulator is on Steam. Not sure what you mean by workaround, but TS2015 is available both on and off Steam. Quote
Simcentral Posted June 23, 2015 Report Posted June 23, 2015 Hello,I am a new user and i recently downloaded your route and train. It is extremely good especially for a beta but i have one question. Will u be adding wheels to the train Quote
briman94 Posted June 23, 2015 Author Report Posted June 23, 2015 Hello,I am a new user and i recently downloaded your route and train. It is extremely good especially for a beta but i have one question. Will u be adding wheels to the trainYes, I'm working on modeling them now Quote
