Mr.NewFlyer1051 Posted February 27, 2020 Report Posted February 27, 2020 2 hours ago, artthouwill said: Was the first time involving an Orange Line train? yep same train same car numbers same spot Quote
artthouwill Posted February 27, 2020 Report Posted February 27, 2020 27 minutes ago, Mr.NewFlyer1051 said: yep same train same car numbers same spot Might be time to retire that car number or consist. If it happens again after that. then it will be time to look at the switches. Quote
Mr.NewFlyer1051 Posted February 27, 2020 Report Posted February 27, 2020 45 minutes ago, artthouwill said: Might be time to retire that car number or consist. If it happens again after that. then it will be time to look at the switches. it’s not the switches it has to be the train either the shoe for the third rail not touching the 3rd rail or something else give it bout a week there’s going to be another orange line stuck there picture is from this morning Quote
rl12383 Posted February 27, 2020 Report Posted February 27, 2020 CTA posted a reroute for this weekend that affects the junction in question. Sounds like they may be working to rectify the problem. Quote
artthouwill Posted February 28, 2020 Report Posted February 28, 2020 2 hours ago, rl12383 said: CTA posted a reroute for this weekend that affects the junction in question. Sounds like they may be working to rectify the problem. Brown and Orange Lines will operate as one route. Trains will run on Wells and Van Buren. Green Line and Pink Line trains will operate via Wells and Van Buren with Pink Line trains terminating at z Roosevelt. Quote
chicagocubs6323 Posted February 28, 2020 Report Posted February 28, 2020 4 hours ago, Mr.NewFlyer1051 said: it’s not the switches it has to be the train either the shoe for the third rail not touching the 3rd rail or something else give it bout a week there’s going to be another orange line stuck there picture is from this morning I'm sorry but that's not from this morning. LOL you've used this picture before. But it is true Purple Line trains terminate at Roosevelt and continue to 63rd to turn back around. Run #514 is a PM run too. 1 Quote
joechicago Posted February 28, 2020 Report Posted February 28, 2020 8 hours ago, Mr.NewFlyer1051 said: yep same train same car numbers same spot Really? Wow. Would’ve thought they learned something the first time Quote
NewFlyerMCI Posted February 28, 2020 Report Posted February 28, 2020 3 hours ago, chicagocubs6323 said: I'm sorry but that's not from this morning. LOL you've used this picture before. But it is true Purple Line trains terminate at Roosevelt and continue to 63rd to turn back around. Run #514 is a PM run too. 12th to 63rd to turn around? The only way I can describe that is just "ew" Quote
NewFlyerMCI Posted February 28, 2020 Report Posted February 28, 2020 4 hours ago, artthouwill said: Brown and Orange Lines will operate as one route. Trains will run on Wells and Van Buren. Green Line and Pink Line trains will operate via Wells and Van Buren with Pink Line trains terminating at z Roosevelt. Seems like whatever the issue is has to do with the inside curve at Tower 12. You'd think they could still run NB/WB Green Line trains, they've left a significant number of stations in the loop without service Quote
artthouwill Posted February 28, 2020 Report Posted February 28, 2020 9 hours ago, chicagocubs6323 said: I'm sorry but that's not from this morning. LOL you've used this picture before. But it is true Purple Line trains terminate at Roosevelt and continue to 63rd to turn back around. Run #514 is a PM run too. Would it have been simpler to turn those Purples at 37th middle track on Green rather than 63rd middle on Red? 1 Quote
chicagocubs6323 Posted February 28, 2020 Report Posted February 28, 2020 3 hours ago, artthouwill said: Would it have been simpler to turn those Purples at 37th middle track on Green rather than 63rd middle on Red? Probably, yeah. That's just what I heard they did last week. Last Friday the same thing happened with literally the same train and at the same spot. Quote
Mr.NewFlyer1051 Posted February 28, 2020 Report Posted February 28, 2020 10 hours ago, NewFlyerMCI said: Seems like whatever the issue is has to do with the inside curve at Tower 12. You'd think they could still run NB/WB Green Line trains, they've left a significant number of stations in the loop without service they aren’t fixing the tower since green line trains to harlem will use that same curve let’s see if there will be a stalled train tomorrow Quote
Mr.NewFlyer1051 Posted February 28, 2020 Report Posted February 28, 2020 15 minutes ago, chicagocubs6323 said: Probably, yeah. That's just what I heard they did last week. Last Friday the same thing happened with literally the same train and at the same spot. last friday purple ended at roosevelt and still had red line passengers up to garfield and then DH to 63rd middle Quote
artthouwill Posted February 28, 2020 Report Posted February 28, 2020 1 hour ago, Mr.NewFlyer1051 said: last friday purple ended at roosevelt and still had red line passengers up to garfield and then DH to 63rd middle I guess that depends on the operator. In the peak direction (SB), Red Line trains are running 2 minute frequencies, so a Purple Line train would be stuck behind a Red Line train anyway. Running empty between Roosevelt and Garfield won't save any time. Might as well carry a couple of passengers. Some operators probably won't do it for safety reasons or too lazy to operate doors for 4 stations. Quote
Tcmetro Posted February 28, 2020 Report Posted February 28, 2020 When the Brown Line was rerouted to the subway a couple years ago for work on the Ravenswood-Loop connector, it ran to Roosevelt, then empty to 63rd Middle Quote
NewFlyerMCI Posted February 28, 2020 Report Posted February 28, 2020 4 hours ago, Mr.NewFlyer1051 said: they aren’t fixing the tower since green line trains to harlem will use that same curve let’s see if there will be a stalled train tomorrow Not the tower, but the switches on the inside curve. If you look at the service pattern, no trains are running on the Wabash and Lake sides. Trains are only running on the outside curve (Van Buren onto S Wabash and vice versa) and not straight thru Wabash and Van Buren onto N Wabash Quote
Mr.NewFlyer1051 Posted February 29, 2020 Report Posted February 29, 2020 4 hours ago, NewFlyerMCI said: Not the tower, but the switches on the inside curve. If you look at the service pattern, no trains are running on the Wabash and Lake sides. Trains are only running on the outside curve (Van Buren onto S Wabash and vice versa) and not straight thru Wabash and Van Buren onto N Wabash north bound trains (brownage and harlem) will use the orange line track where the orange line stalled at Quote
WCR Posted February 29, 2020 Report Posted February 29, 2020 There's currently an eight-car red line set parked dead on the siding between Garfield and 63rd. Anyone know why it's stored there, maybe it has something to do with the massive delays from the incident at Grand this afternoon? Or even the reroutes mentioned above? Quote
NewFlyerMCI Posted February 29, 2020 Report Posted February 29, 2020 1 hour ago, WCR said: There's currently an eight-car red line set parked dead on the siding between Garfield and 63rd. Anyone know why it's stored there, maybe it has something to do with the massive delays from the incident at Grand this afternoon? Or even the reroutes mentioned above? Could it be a Purple Line waiting to deadhead back to Howard/Linden? Quote
NewFlyerMCI Posted February 29, 2020 Report Posted February 29, 2020 5 hours ago, Mr.NewFlyer1051 said: north bound trains (brownage and harlem) will use the orange line track where the orange line stalled at So the North to West outside curve? What's the point then, they could have NB/WB trains use the Wabash/Lake sides of the loop and not leave it completely OOS Quote
WCR Posted February 29, 2020 Report Posted February 29, 2020 34 minutes ago, NewFlyerMCI said: Could it be a Purple Line waiting to deadhead back to Howard/Linden? I doubt it. It was an eight car set and I noticed at least one pair was in the 5500s. All headlights, markers, interior lighting were all off. Quote
artthouwill Posted February 29, 2020 Report Posted February 29, 2020 12 hours ago, WCR said: There's currently an eight-car red line set parked dead on the siding between Garfield and 63rd. Anyone know why it's stored there, maybe it has something to do with the massive delays from the incident at Grand this afternoon? Or even the reroutes mentioned above? Possibly a mechanical problem. It could have been moved there temporarily so as not to disrupt service trying to deadhead it back to either 98th Yard or Howard Yard. Obviously 98th is much closer, but depending on the time of the issue, space there may have been an issue. Trying to deadhead it to Howard may have caused more delays if another malfunction occurred. If the incident occurred at Grand (assuming a SB train), 63rd middle was the next place to get the train out of the way. Is there an update on the train being moved? Update: shooting occurred at Grand involving the police. Quote
WCR Posted February 29, 2020 Report Posted February 29, 2020 31 minutes ago, artthouwill said: Is there an update on the train being moved? Train was gone as of about 10am today Quote
Mr.NewFlyer1051 Posted March 1, 2020 Report Posted March 1, 2020 23 hours ago, WCR said: Train was gone as of about 10am today test train (possible) for the loop last night i heard over cta rail ops dispatch said (test train what is your location) the test train was for the track improvement work on lake and wabash Quote
artthouwill Posted March 1, 2020 Report Posted March 1, 2020 46 minutes ago, Mr.NewFlyer1051 said: test train (possible) for the loop last night i heard over cta rail ops dispatch said (test train what is your location) the test train was for the track improvement work on lake and wabash I think the train he saw was the train involved in the shooting of a person by a police officer at Grand and State Red Line station Friday afternoon. Quote
