qwantae Posted December 6, 2017 Report Posted December 6, 2017 What was that Orion # that is sitting next to 6160 at South? I assume that one also just came from West recently as well. I wasn't quite expecting that 2004 Orions to end already. Quote
Busjack Posted December 6, 2017 Report Posted December 6, 2017 12 hours ago, qwantae said: What was that Orion # that is sitting next to 6160 at South? I assume that one also just came from West recently as well. I wasn't quite expecting that 2004 Orions to end already. Putting it under quadruple magnification, the license plate looks like 6123, but I can't be absolutely sure. Side number starts with 61. Quote
garmon757 Posted December 6, 2017 Report Posted December 6, 2017 4 hours ago, Busjack said: Putting it under quadruple magnification, the license plate looks like 6123, but I can't be absolutely sure. Side number starts with 61. That is indeed #6123. I had to deeply spread the photo on my phone with my two fingers in order to zoom it well. I examined the side and the third number had to be either a 2 or 3 base off the tiny piece but I knew every bus in the 6130s are gone except for #6132. That bus is still in service. Also, most buses have their license plates end with the exact four numbers that matches their respective bus numbers. In this case, #6123 is a match of the last four numbers on its license plate. Quote
qwantae Posted December 7, 2017 Report Posted December 7, 2017 5 hours ago, garmon757 said: That is indeed #6123. I had to deeply spread the photo on my phone with my two fingers in order to zoom it well. I examined the side and the third number had to be either a 2 or 3 base off the tiny piece but I knew every bus in the 6130s are gone except for #6132. That bus is still in service. Also, most buses have their license plates end with the exact four numbers that matches their respective bus numbers. In this case, #6123 is a match of the last four numbers on its license plate. Yes, I see #6132 is still working the 301 this evening. Quote
Busjack Posted December 7, 2017 Report Posted December 7, 2017 6 hours ago, garmon757 said: Also, most buses have their license plates end with the exact four numbers that matches their respective bus numbers Pace did that consistently through the base orders of the 6162s and 6600s. Then it fell apart, especially with some M1262xxs used on the second option 6600s, making those plates unavailable for the 6262s. 1 Quote
garmon757 Posted December 7, 2017 Report Posted December 7, 2017 1 hour ago, Busjack said: Pace did that consistently through the base orders of the 6162s and 6600s. Then it fell apart, especially with some M1262xxs used on the second option 6600s, making those plates unavailable for the 6262s. Well, that just filled the holes in why 6262s didn’t have identical plates. Quote
Busjack Posted December 8, 2017 Report Posted December 8, 2017 Only NABI on a NS route this afternoon is 6263. Quote
Busjack Posted December 18, 2017 Report Posted December 18, 2017 I dud a quick circuit of South Holland, and the only thing that looked new there were 17000 series paratransits. Axess buses seemed about as @Pace831 described, i.e. in the 6730s to 6750s. Most were too far from 167th St. to figure out without binoculars, which I didn't have. 1 Quote
artthouwill Posted December 29, 2017 Report Posted December 29, 2017 Those 6600 series NABIs won't go away. 6672 was out on 301 yesterday. Quote
Busjack Posted December 29, 2017 Report Posted December 29, 2017 1 hour ago, artthouwill said: Those 6600 series NABIs won't go away. 6672 was out on 301 yesterday. 6651 also seems to be a long liver. Quote
rotjohns Posted December 29, 2017 Report Posted December 29, 2017 9 hours ago, artthouwill said: Those 6600 series NABIs won't go away. 6672 was out on 301 yesterday. If 6700s make their way to West, they'll be gone. Looks like Pace has slowed down putting new buses in service, probably because of the cold and snow. Quote
Busjack Posted December 29, 2017 Report Posted December 29, 2017 9 minutes ago, rotjohns said: If 6700s make their way to West, they'll be gone. Looks like Pace has slowed down putting new buses in service, probably because of the cold and snow. Well, it is the holidays, and they also probably remember when 2635 got damaged in a pile up on the Tri-State attempting to get to Highland Park. Quote
artthouwill Posted December 31, 2017 Report Posted December 31, 2017 On 12/29/2017 at 8:46 AM, Busjack said: 6651 also seems to be a long liver. Sure is. Out on 330 yesterday. Great heat and horrible suspension. Quote
qwantae Posted January 3, 2018 Report Posted January 3, 2018 On 12/8/2017 at 5:48 PM, Busjack said: Only NABI on a NS route this afternoon is 6263. No longer at NS, Moved to West as working on the 308 today PM Rush. Quote
Erin Mishkin Jr. Posted January 10, 2018 Report Posted January 10, 2018 Since many Webwatch sightings, I did not see bus 6366 in service on any route. Does anyone know why 6366 has not been going out? 1 Quote
andrethebusman Posted January 10, 2018 Report Posted January 10, 2018 Latest from PACE SPacebus So18010408120.pdf 4 Quote
Busjack Posted January 10, 2018 Report Posted January 10, 2018 29 minutes ago, andrethebusman said: Latest from PACE SPacebus So18010408120.pdf 2727 is MIA Confirms that any Orion VIs are in the junk lot. Says 6701, 6702 are going to Fox Valley (Aurora) Says only 6730-6733 at North--I guess as of Monday the rest have not been assigned. I'm not sure what the green means. 2830, 2831 and 8624-8630 are painted green, but the South-2 buses appear to be Ravinia buses (at least so assigned there last summer). 1 Quote
rotjohns Posted January 10, 2018 Report Posted January 10, 2018 4 minutes ago, Busjack said: 2727 is MIA Confirms that any Orion VIs are in the junk lot. Says 6701, 6702 are going to Fox Valley (Aurora) Says only 6730-6733 at North--I guess as of Monday the rest have not been assigned. I'm not sure what the green means. 2830, 2831 and 8624-8630 are painted green, but the South-2 buses appear to be Ravinia buses (at least so assigned there last summer). 2727 is assigned to MV Transportation Batavia. It runs with 2728-2735 along routes 674, 709, 711, & 715. It's on 715 now. 1 Quote
Busjack Posted January 10, 2018 Report Posted January 10, 2018 6 minutes ago, rotjohns said: 2727 is assigned to MV Transportation Batavia. ... It's on 715 now. Must be a clerical error. That's where I figured it should be. Quote
andrethebusman Posted January 10, 2018 Report Posted January 10, 2018 Green might mean not blue or yellow? Namely, ad buses? Quote
Busjack Posted January 10, 2018 Report Posted January 10, 2018 10 minutes ago, andrethebusman said: Green might mean not blue or yellow? Namely, ad buses? A couple of red ads, but that probably on only one 6000 and 6618 (which is blue on the list) .Certainly doesn't account for all the wrapped Axess buses (such as Wrigley Field Express, I-90 promotion). While I assume that Purple is for Pulse, the motor coaches and express buses are not distinguished, even though those on I-55 and I-90 are also wrapped or decaled. Quote
busfan2847 Posted January 10, 2018 Report Posted January 10, 2018 32 minutes ago, andrethebusman said: Green might mean not blue or yellow? Namely, ad buses? 2830 and 2831 are Pace's two hybrid Orions - perhaps that is why they are green. Quote
Busjack Posted January 10, 2018 Report Posted January 10, 2018 5 minutes ago, busfan2847 said: 2830 and 2831 are Pace's two hybrid Orions - perhaps that is why they are green. Actually, the buses are painted green because they are hybrids, which wouldn't explain the entries for 8624-30, except that the trolleys are also painted green Quote
rotjohns Posted January 19, 2018 Report Posted January 19, 2018 On 1/10/2018 at 7:29 AM, Erin Mishkin Jr. said: Since many Webwatch sightings, I did not see bus 6366 in service on any route. Does anyone know why 6366 has not been going out? Looks like per the latest roster, 6366 is not in existence. Skipped possibly? Quote
busfan2847 Posted January 19, 2018 Report Posted January 19, 2018 1 hour ago, rotjohns said: Looks like per the latest roster, 6366 is not in existence. Skipped possibly? Looking at my records the last time 6366 showed up on webwatch was November 2016. Pace 831 posted a photograph on 8/31/2017 at Chandler ( https://chitransit.org/topic/1732-new-eldorados/?page=49 ) of 17522 behind a fence. If you blow up the image and look in the right hand doorway above the back of 17522 you will see 6366. Has it had a crash that has required Chandler to rebuild it or has it been decided it as beyond economic repair. Quote
