geneking7320 Posted July 18, 2016 Report Posted July 18, 2016 Hi All; Can someone refresh my memory as to why CTA removed those seats at the cab end of some 5K's? Thanks! 1 Quote
Busjack Posted July 18, 2016 Report Posted July 18, 2016 22 minutes ago, geneking7320 said: Hi All; Can someone refresh my memory as to why CTA removed those seats at the cab end of some 5K's? Thanks! Supposedly to place a barrel of deicing fluid there. Quote
RJL6000 Posted July 20, 2016 Report Posted July 20, 2016 On 7/11/2016 at 6:42 PM, chgofan78 said: Noticed today that all of those Red Line 5000-series cars that were helping out on the Green Line have made their way back to the Red Line. However, the Green Line got a few 5370s in return (at least #5371-72 were on the Green Line the past few days). Quote
BusHunter Posted July 21, 2016 Report Posted July 21, 2016 I was told the green line got #5187-90 off the red line so I put it on the roster. Quote
chgofan78 Posted July 21, 2016 Report Posted July 21, 2016 I wonder if they are starting to prep for the additional service coming soon. Quote
andrethebusman Posted July 26, 2016 Report Posted July 26, 2016 7/1/16 assignments: 5001-5054 Pink 5055-5186 Green 5187-5400 Red except 5217-20,5225-26,5231-32,5235-36,5251-52 on Green 5401-5500 Purple 5501-5516 Red 5517-5526 Yellow - 5517-18 stored wrecked 5527-5714 Red Quote
Juniorz Posted July 27, 2016 Report Posted July 27, 2016 Wish 5713-5714 would've stayed at their intended line, but oh well. Quote
Busjack Posted August 16, 2016 Report Posted August 16, 2016 42 minutes ago, andrethebusman said: The L is overloaded with cars because they decided to keep enough cars on hand to run the Red Line extension to Roseland, which would probably need six more trainsets, at least. However, this is more wishful thinking than real forecasting. With luck, we might see the extension by 2030 or 2040. Numbers about correspond to what the Orange Line would have needed if "the Orange Line is going to get 5000s." This sounds kind of wasteful though. Maybe the issue is how much the Crowd Reduction Plan really increased Red and Brown Line service. Quote
Busjack Posted November 8, 2016 Report Posted November 8, 2016 The old Google came up with an NBC5 picture of a Cubs L car. Quote
2490 Posted November 10, 2016 Report Posted November 10, 2016 Any clues on which runs the W cars will be running on? Quote
cta5658 Posted November 10, 2016 Report Posted November 10, 2016 2 hours ago, 2490 said: Any clues on which runs the W cars will be running on? Check the Red Line, you most likely may see them there Quote
2490 Posted November 10, 2016 Report Posted November 10, 2016 7 hours ago, cta5658 said: Check the Red Line, you most likely may see them there Yes, but looking for a run number if possible. It would make it a lot easier to find on the train tracker for somebody from 1500 miles away in town Quote
sw4400 Posted November 10, 2016 Report Posted November 10, 2016 52 minutes ago, 2490 said: Yes, but looking for a run number if possible. It would make it a lot easier to find on the train tracker for somebody from 1500 miles away in town Logically, the run number should be 1908 or 2016 if you wanted the train marked specifically. But, it's just a 5000-Series set of cars wrapped in Cubs logos, flags, etc...... , so it's not so special to have a outstanding run number. To make it special, maybe have Jason Heyward, Anthony Rizzo, Ben Zobrist and David Ross signing autographs and taking pictures, then you'll have a legitimate reason to put a special run number for the train...... oh, and good luck boarding, because it'll be as crammed as the Holiday Train, which is coming in a few weeks and brought to you by chitransit.org(we're not sponsoring the Holiday Train!!!!!! I just wanted to try my hand at a shameless plug ). 1 Quote
Busjack Posted November 10, 2016 Report Posted November 10, 2016 1 hour ago, sw4400 said: Logically, the run number should be 1908 or 2016 if you wanted the train marked specifically. But he wasn't talking about the equivalent of the now cannibalized 1892-1992 2000s. What he wants is the run number, such as 830, so it can track it on the map. and catch it. Not that I am saying what the actual run number is, since I don't know. But the task is not as easy as finding bus 1763 on 152, since trains are not tracked by car numbers. Quote
Pace831 Posted November 10, 2016 Report Posted November 10, 2016 I would suppose the cars aren't assigned to any particular run, and finding them must involve some amount of luck. Quote
2490 Posted November 10, 2016 Report Posted November 10, 2016 33 minutes ago, Busjack said: But the task is not as easy as finding bus 1763 on 152, since trains are not tracked by car numbers. However that is helpful as I'll be searching for the bus as well. Thank you Quote
sw4400 Posted November 10, 2016 Report Posted November 10, 2016 1 hour ago, Busjack said: But he wasn't talking about the equivalent of the now cannibalized 1892-1992 2000s. What he wants is the run number, such as 830, so it can track it on the map. and catch it. Not that I am saying what the actual run number is, since I don't know. But the task is not as easy as finding bus 1763 on 152, since trains are not tracked by car numbers. @Busjack, you can personalize run numbers for special trains. Santa Train is usually designated Run #1225 on the Train Tracker and the retirement of the 2400-Series Railcars were supposed to be specially designated Run #2400 on the Train Tracker so people know when the train(s) are due(if I recall correctly, they did the 2200-Series retirement cars as Run #2200). If CTA wanted to, they could've designated the Run # to be 1908 or 2016, to easily identify the train on Train Tracker, but it's not that important to do so. Quote
Busjack Posted November 10, 2016 Report Posted November 10, 2016 But that still doesn't do any good the person making the request, unless CTA actually does it, such as when Santa appeared on the BusTracker map, and certainly isn't reflected in any of the pictures you captured (and I sure hope you embedded them rather than copied and posted them, but based on the links it looks like you didn't, and if you didn't you violated TrendeRende's copyright). Quote
sw4400 Posted November 11, 2016 Report Posted November 11, 2016 Maybe it is using a special run number...... Quote
MTRSP1900-CTA3200 Posted November 11, 2016 Report Posted November 11, 2016 2 minutes ago, sw4400 said: Maybe it is using a special run number...... I just did a quick check. All Red Line trains at the time have 800 and 900 run numbers. And as far as I know, the 5000s can only display three digits of run numbers. So 2016 would either look like 201 or 016, which are run numbers that belong to the Blue and Green lines respectively. Quote
sw4400 Posted November 11, 2016 Report Posted November 11, 2016 1 minute ago, MTRSP1900-CTA3200 said: I just did a quick check. All Red Line trains at the time have 800 and 900 run numbers. And as far as I know, the 5000s can only display three digits of run numbers. So 2016 would either look like 201 or 016, which are run numbers that belong to the Blue and Green lines respectively. So how did they get the run number show above in the photo? Quote
2490 Posted November 11, 2016 Report Posted November 11, 2016 15 minutes ago, sw4400 said: So how did they get the run number show above in the photo? Same way they got the street cars in the photo... Photoshop Quote
Busjack Posted November 11, 2016 Report Posted November 11, 2016 2 hours ago, 2490 said: Same way they got the street cars in the photo... Photoshop Probably the converse, but you have a real good eye. It appears that the original is from the poster I mentioned a couple of weeks ago of the 1945 World Series, with Peter Witt streetcars on Clark Street. Note also the marquee from that era. Based on the L crossing Clark Street (there definitely were not streetcars on Addison, which was a CMC route), the L would have been running on Eddy St., and we know it doesn't. The best one could say of the placement would be on Roscoe, but it isn't a Brown Line train. In short, CTA fooled someone. Quote
BusHunter Posted November 12, 2016 Report Posted November 12, 2016 #5303-04 and #5695-96 are currently coming south on run #933. First four cars are the cubs wrapped w cars approaching Clark division. 2 Quote
