Shannoncvpi Posted March 1, 2022 Report Posted March 1, 2022 9 hours ago, artthouwill said: Whether it gets repaired or not will probably depend on how much frame damage was done. Exactly bro all depends if the frame hurt its retired it will stay in the boneyard till cta scrap it or till the 7900's old enought to retire then scrap it like 4300's their not old enought to be retired so thats why 4323 is sitting in the yard as a parts bus till it gets scarpped but depends on how cta feels cause 4333 I think been scapped cause its not in the boneyard Quote
Bus1883 Posted March 1, 2022 Report Posted March 1, 2022 2 hours ago, Shannoncvpi said: Exactly bro all depends if the frame hurt its retired it will stay in the boneyard till cta scrap it or till the 7900's old enought to retire then scrap it like 4300's their not old enought to be retired so thats why 4323 is sitting in the yard as a parts bus till it gets scarpped but depends on how cta feels cause 4333 I think been scapped cause its not in the boneyard #4333 should be in between west shops and the garage of Vincennes ave I think Quote
YoungBusLover Posted March 1, 2022 Report Posted March 1, 2022 1 hour ago, Bus1883 said: #4333 should be in between west shops and the garage of Vincennes ave I think Only half of #4333 is there. Along with the shell of a #6400 front frame. Quote
Bus1883 Posted March 1, 2022 Report Posted March 1, 2022 1 hour ago, YoungBusLover said: Only half of #4333 is there. Along with the shell of a #6400 front frame. Wow, RIP to the other piece of #4333 Quote
Shannoncvpi Posted March 1, 2022 Report Posted March 1, 2022 1 hour ago, YoungBusLover said: Only half of #4333 is there. Along with the shell of a #6400 front frame. Yea its invetween the bus ways & the West end of SS Quote
Erin Mishkin Jr. Posted March 2, 2022 Report Posted March 2, 2022 A friend rode 8257 this morning on the 92, the bus broke down at around 7:30 am on foster & Cicero heading east. Bus shut down and would not restart. Quote
artthouwill Posted March 2, 2022 Report Posted March 2, 2022 2 hours ago, Erin Mishkin Jr. said: A friend rode 8257 this morning on the 92, the bus broke down at around 7:30 am on foster & Cicero heading east. Bus shut down and would not restart. I wonder if the driver tried ( or allowed to) restart the bus from the rear? Years ago i was driving a commuter route to Gary and as I was exiting the Indians Toll Road, my bus shut off. I was able to get on the exit ramp. I couldn't restart the bus. U saw i had plenty of fuel and the bus wasn't overheated. I decided to leave the master switch on and see if I could start the bus from the back. It worked. Once it started, I flipped the rear starter switch from rear start back to front start and finished the run I guess buses are designed to run in the rear start position for a limited time (maybe a couple of hoyrs). Sometimes mechanics or feelers or those who check fluids shut the bus down and restart the bus Fri the rear but forget to flip the switch back to front start Can't say for sure this happened here, but it's a possibility Quote
Sam92 Posted March 2, 2022 Report Posted March 2, 2022 31 minutes ago, artthouwill said: I wonder if the driver tried ( or allowed to) restart the bus from the rear? Years ago i was driving a commuter route to Gary and as I was exiting the Indians Toll Road, my bus shut off. I was able to get on the exit ramp. I couldn't restart the bus. U saw i had plenty of fuel and the bus wasn't overheated. I decided to leave the master switch on and see if I could start the bus from the back. It worked. Once it started, I flipped the rear starter switch from rear start back to front start and finished the run I guess buses are designed to run in the rear start position for a limited time (maybe a couple of hoyrs). Sometimes mechanics or feelers or those who check fluids shut the bus down and restart the bus Fri the rear but forget to flip the switch back to front start Can't say for sure this happened here, but it's a possibility When you say from the back you mean flipping the hood behind the bus? Quote
artthouwill Posted March 2, 2022 Report Posted March 2, 2022 48 minutes ago, Sam92 said: When you say from the back you mean flipping the hood behind the bus? Yes. The hood has to be opened to access the switch. Quote
YoungBusLover Posted March 2, 2022 Report Posted March 2, 2022 1 hour ago, artthouwill said: I wonder if the driver tried ( or allowed to) restart the bus from the rear? Years ago i was driving a commuter route to Gary and as I was exiting the Indians Toll Road, my bus shut off. I was able to get on the exit ramp. I couldn't restart the bus. U saw i had plenty of fuel and the bus wasn't overheated. I decided to leave the master switch on and see if I could start the bus from the back. It worked. Once it started, I flipped the rear starter switch from rear start back to front start and finished the run I guess buses are designed to run in the rear start position for a limited time (maybe a couple of hoyrs). Sometimes mechanics or feelers or those who check fluids shut the bus down and restart the bus Fri the rear but forget to flip the switch back to front start Can't say for sure this happened here, but it's a possibility Well now only supervisors and mechanics have keys to unlock certain components on the buses we have now. Sometimes they'll attempt to reset the battery to try and jump start the bus but if all else fails the mechanics will come and try to retify the problem since they have more equipment. Normally a hard reset will work. The Flyers are alot different than the novas are though so the process could be a bit different. Quote
artthouwill Posted March 2, 2022 Report Posted March 2, 2022 3 minutes ago, YoungBusLover said: Well now only supervisors and mechanics have keys to unlock certain components on the buses we have now. Sometimes they'll attempt to reset the battery to try and jump start the bus but if all else fails the mechanics will come and try to retify the problem since they have more equipment. Normally a hard reset will work. The Flyers are alot different than the novas are though so the process could be a bit different. With the way school kids used to open hoods and shut fown buses, I guess it makes sense for CTA to restrict access to the engine compartment. Also I thought about work rules that might protect drivers from possible injury messing around in the engine compartment. Some companies don't allow drivers to touch anything while other companies have their drivers check and fill fluids. I know drivers that can change belts (alternator belts). Quote
Mr.NewFlyer1051 Posted March 2, 2022 Report Posted March 2, 2022 2 hours ago, artthouwill said: I wonder if the driver tried ( or allowed to) restart the bus from the rear? Years ago i was driving a commuter route to Gary and as I was exiting the Indians Toll Road, my bus shut off. I was able to get on the exit ramp. I couldn't restart the bus. U saw i had plenty of fuel and the bus wasn't overheated. I decided to leave the master switch on and see if I could start the bus from the back. It worked. Once it started, I flipped the rear starter switch from rear start back to front start and finished the run I guess buses are designed to run in the rear start position for a limited time (maybe a couple of hoyrs). Sometimes mechanics or feelers or those who check fluids shut the bus down and restart the bus Fri the rear but forget to flip the switch back to front start Can't say for sure this happened here, but it's a possibility i see it happen plenty of times on the 1000’s seems as the 7900’s get the bigger beat down then 1000’s Quote
YoungBusLover Posted March 2, 2022 Report Posted March 2, 2022 2 hours ago, artthouwill said: With the way school kids used to open hoods and shut fown buses, I guess it makes sense for CTA to restrict access to the engine compartment. Also I thought about work rules that might protect drivers from possible injury messing around in the engine compartment. Some companies don't allow drivers to touch anything while other companies have their drivers check and fill fluids. I know drivers that can change belts (alternator belts). You're correct, now sometimes you'll see some operators out here locking and unlocking those compartments if they were lucky enough to get a key but I've only see that a rare amount of times. It does still post a safety risk though when those doors are left unlocked by accident. Quote
jajuan Posted March 3, 2022 Report Posted March 3, 2022 On 2/28/2022 at 8:48 PM, artthouwill said: Whether it gets repaired or not will probably depend on how much frame damage was done. Yeah that's why I didn't want to speculate too far on that front because the video alone doesn't provide any clues about frame damage. All we could see really is obvious outer cosmetic damage. Quote
Erin Mishkin Jr. Posted March 4, 2022 Report Posted March 4, 2022 1816 broke down earlier this afternoon, operated on 50 Damien. Quote
Erin Mishkin Jr. Posted March 8, 2022 Report Posted March 8, 2022 1713 possibly broke down on Saturday and was spotted being towed back to North Park garage with exterior lights on down in the south side. Quote
Erin Mishkin Jr. Posted March 8, 2022 Report Posted March 8, 2022 4170 was broken down earlier this afternoon near Lake Shore Drive, a emergency van was behind it working to correct the issue Quote
Erin Mishkin Jr. Posted March 21, 2022 Report Posted March 21, 2022 6 hours ago, Policeman said: 4144 broke down Need it now? Sounds like 4144 needed a breakdown from GoPuff I guess...oh well. Reminds me of the pace paratransit vehicle I saw broken down on North ave today Quote
BusHunter Posted March 30, 2022 Report Posted March 30, 2022 This morning one of the new #8325's needed a tow from Cumberland Belmont terminal saw it going to work shortly after 5am. Then I saw around 730 #1941 being hooked up to truck #250 at Fullerton and Kostner. It might have been the same wrecker at Belmont. It was the small one. Then a few minutes before the kostner appearance, I saw the other truck #250 on Pulaski. So I saw 3 trucks but maybe the same one twice. Quote
Erin Mishkin Jr. Posted March 30, 2022 Report Posted March 30, 2022 5 hours ago, BusHunter said: This morning one of the new #8325's needed a tow from Cumberland Belmont terminal saw it going to work shortly after 5am. Then I saw around 730 #1941 being hooked up to truck #250 at Fullerton and Kostner. It might have been the same wrecker at Belmont. It was the small one. Then a few minutes before the kostner appearance, I saw the other truck #250 on Pulaski. So I saw 3 trucks but maybe the same one twice. that one was 8348 just checked maths Quote
Bus1883 Posted April 22, 2022 Report Posted April 22, 2022 #7966 broke down today around 6:20 PM this evening not too far from the garage 1 Quote
NovaBusFan Posted April 22, 2022 Report Posted April 22, 2022 16 minutes ago, Bus1883 said: #7966 broke down today around 6:20 PM this evening not too far from the garage 8 years of these trash buses, I hope 77th dump these away one day?? Quote
BusHunter Posted April 22, 2022 Report Posted April 22, 2022 3 hours ago, NovaBusFan said: 8 years of these trash buses, I hope 77th dump these away one day?? Hate to say it but more Novas are on the way. What you really need is a time machine set to 2040!!? Quote
