6 minutes ago, YoungBusLover said:
Well 74th trains there drivers mainly on Ashland Ave, rarely do I see them training outside of Ashland, 77th sort of trains everywhere from what i've seen sometimes 87th,Ashland and Western. Depending on the garage and the training routes approved from the higher brass determines where drivers get there training. So maybe Cermak is an approved area to train since it does have a little bit of every surface street you could imagine with numerous obstacles to get use to, such as transitions between two lane streets to four and even six lane avenues, you factor in traffic,parked cars,pedestrians,very tight turns if you're starting point is near McCormick Place, you pretty much get a little bit of everything traveling along cermak.
Exactly I say Madison the same way lol
Seen 1054 & 55 going into C back to back after the rush hour run both still sporting 3 in the windshield dam C take a long time to change stickers while 7 seem to change theirs as soon as they get a bus
7 hours ago, Mr.NewFlyer1051 said:
Now it’s time to go on a hunt for 1342 that also means 1805 and 4167 and 1305 and the rest of them are coming back also
#1305 isn't coming back, its already missing parts and other components. #1805 and #4167 may come back but only time will tell.
14 minutes ago, Mr.NewFlyer1051 said:
1805 and 4167 will come back by next spring and what happened to 1305
#1305 has an odd story but I can't remember exactly how it ended up at south shops but it has been defunct since 2012 or 2013, It had heavy structural damage in the rear.
What Happened to 1305 btw never seen it since it's been retired they hiding it dam good
Naw 1305 done with it's been oos since 12-13 that's way too long to be down for repairs it's done with
1 hour ago, Shannon CVPI said:
Whatever happened to 1305 was it in a bad accident of some shit
Watch the language and I already gave an idea as to what happened to #1305, if you look through the archives you'll get an idea of what may of happened to it.
Mybad broham & bet I'll look back through it
4 hours ago, Mr.NewFlyer1051 said:
1380-1386 C>FG
1390-1392 C>FG
1562-1563 K>74th
Have these moves already occured or are you just speculating (again)?
So ten more Flyers leaving C...it looks like the first Proterras could be here within a matter of days. Hopefully progress on the chargers is sped up a bit.
