Well, thanks for the history about the 53AL. It makes a lot more sense as to why it existed now. Chicago Transit and Railfan gives its operation dates as 11/7/1993 - 2/7/2010. 3L is given a start date of 3/28/1993, which puts it a month after the swapping of the north and south ends of the Red and Green and 9 months before the closure of the Green Line for reconstruction.
#1655 and #1659 are on #53. #1661 is on #54B. #1636 is on #65. #1647 is on #70. #1641 is on #72. #1639, #1651, and #1677 are on #74.
#1003 and #1444 are on #21.
#6833 is off the pending list of retirement. Currently on #67.
Looks like they are trying to get these excessive unrehabbed buses away from Kedzie. (#1600's for #1400's) 117 left is a bit much. But i don't know about sending them to Chicago. All they are doing is taking Kedzie's problem and making it Chicago's and they have 80 #6400's to play with, so in a way that's worse. They probably should have sent those #1600's to 74th as they have a pretty good fleet now, #6800's and the lowest unrehabbed bus count, 23. 74th rehabs fast too like Chicago so together they probably could have worked to get the 117 down to manageable levels. Besides 74th should have alot of extra buses with the #8000's coming. It's not ridiculous there to send out 10-15 rehabs at a time now.
It's like a chain reaction because no garage is safe. It's like playing a game of Cta Busnopoly! :lol:
This morning I see 1438 and 1441 is on #124 and and #1657 is on #20.
So what did Chicago get all the buses up to #1680, in the #1600's that are not rehabbed? NP has the rest higher than #1680.
#1669 is still on the #21, so I don't know if it could be rehabbed or it just hasn't moved yet. Kedzie still has #1675 and that's rehabbed so it looks like only the unrehabbed buses from Kedzie went to Chicago and the rehabbed #1400's from Chicago went to Kedzie. #1449 though is still at Chicago. Counting what's unrehabbed at Kedzie for #1600's (#1630 - #1680) that amounts to 25 buses. Take away 5 or so buses at South shops and it looks like a 20 bus swap.
I think Kedzie is attempting to get as many #1600's as they can. It is a Saturday, so some might have fallen through the cracks, but if NP has the 20 #1600's that are #1680 and higher, Kedzie is either borrowing or taking them bit by bit (or bus by bus) since #1685 is on 18, #1688 is on 52, #1694 is on #10.
I'm glad #6833 got patched up after what happened to it.
Damn #1007 is released from south shops on the #53!!
#1271 is also on the #21 released from south shops. That was a 103rd bus and so was #1007.
#1336 has also been released from south shops to the #36. That was a 74th bus
What exactly happened to #6833? I know #6832 was out of service due to a accident. Can you enlighten me about #6833?
Then they must be starting on Washington/Wabash either before or in conjuction with Washington/Wells renovation. CTA sure loves its infill stations
How do you figure it is infill if it is replacing Randolph/Wabash and Madison/Wabash?
The only thing this signals is that they need to get Madison out of the way to get construction started.
The engine cover panel to the left of the rear window was crumbled in the air like a tin can and I couldn't tell at the time that I saw it sitting @ southshops whether or not it had significant damage to the engine up until the time I heard it got released, but other than that I have no clue as to why that happened.
P only has the non-refurbished 1600 higher than 1681 from K via 74th (1682-4/9/93/5/7/8). The rest, including the ones you listed, have never moved from K since new in May 2008.
Actually, some of the 1600's have been scattered from K....
1636,1639,1641,1647,1651,1653,1655,1657-1659,1661,1677 are at Chicago
1682-1684,1689,1693,1695,1697-1698 are at North Park
1608,1610,1612,1614-1615 are at 74th
1601,1603,1606,1620 are at 77th
1600,1602,1604-1605,1607,1609,1611,1613,1616-1618 are at 103rd
Kedzie did have almost this entire block a few years back.... most of the 1600-1629 block and all of the 1630-1699 block, but now those numbers are scattered, whether temporarily or permanently among other garages. I wonder if one day the D40LF blocks will be consolidated together at the various garages(e.g: 1700-1799 at NP, 1800-1899 at K, 1900-1999 at C, 2000-2029 at FG, etc...)
Now that's weird. #1640 is still at kedzie on the #82 and #1633 is on the #21. Both should be unrehabbed. #1663 is at kedzie too. No way could all these buses be rehabbed??? Just in case they are I'll stick around and check out #1669.
Later on...
#1633 and #1663 are not rehabbed on the #21 so looks like they only moved some of the unrehabbed #1600's.
