Mr.NewFlyer1051 Posted July 15, 2020 Report Posted July 15, 2020 Just now, Pink Jazz said: I previously mentioned that CTA may run a common fleet on Blue, Green, and Pink, and this appears to be what CTA is hinting at. It appears that Green/Blue/Pink will operate with 5000s while Red/Purple/Yellow/Orange/Brown will operate with 7000s once all cars are delivered. CTA cannot run 5000’s past racine the CB needs to be rebuilt like the dan ryan in order for CTA to run 5000’s or 7000’s on that part of the line 1 Quote
Sam92 Posted July 16, 2020 Report Posted July 16, 2020 6 hours ago, Mr.NewFlyer1051 said: CTA cannot run 5000’s past racine the CB needs to be rebuilt like the dan ryan in order for CTA to run 5000’s or 7000’s on that part of the line Eh I think if enough cars come in and the power is upgraded 5000's might end up there due to sheer numbers if the track and road bed isn't fixed. 5000's showed up on the red line before it was rebuilt, the timing was jsut more of a coincidence and it was preferred to not have 5000's en mass on the red until the Dan Ryan was finished but even if there wasn't funding I'm pretty sure red would have got the 5000's still because everything else (power and signal) was redone not too long before Quote
artthouwill Posted July 16, 2020 Report Posted July 16, 2020 17 hours ago, Sam92 said: Eh I think if enough cars come in and the power is upgraded 5000's might end up there due to sheer numbers if the track and road bed isn't fixed. 5000's showed up on the red line before it was rebuilt, the timing was jsut more of a coincidence and it was preferred to not have 5000's en mass on the red until the Dan Ryan was finished but even if there wasn't funding I'm pretty sure red would have got the 5000's still because everything else (power and signal) was redone not too long before Remember 2 things. First, CTA said they wouldn't assign 5000s to the Red Line unless they could shut down the Dan Ryan branch to rebuild it. Second, the Red Line service was rerouted to Ashand/63 while the 5000s were being assigned to the Red Line. Quote
Sam92 Posted July 16, 2020 Report Posted July 16, 2020 1 hour ago, artthouwill said: Remember 2 things. First, CTA said they wouldn't assign 5000s to the Red Line unless they could shut down the Dan Ryan branch to rebuild it. Second, the Red Line service was rerouted to Ashand/63 while the 5000s were being assigned to the Red Line. I mean they SAID that but I remember they started had a good 44 cars by the time the shutdown happened. They just happened to finish while on the reroute Quote
artthouwill Posted July 17, 2020 Report Posted July 17, 2020 On 7/16/2020 at 6:18 PM, Sam92 said: I mean they SAID that but I remember they started had a good 44 cars by the time the shutdown happened. They just happened to finish while on the reroute They went ahead and started assembling them because they knew they had the shutdown plan in place. If the Forest Park branch were to be shortened to UIC or rerouted to the Punk Line with a definitive date for the branch shutdown, you will see 5000s or 7000s start to appear on the Blue Line. Even after the O'Hare branch power upgrades are completed, if enough 2600s go into disrepair, you might see 5000s on the Blue Line still. A scant few might run the full route, but I think they would try to limit those cars to service between UIC and ORD For now the 3200s should so the trick Quote
Mr.NewFlyer1051 Posted July 17, 2020 Report Posted July 17, 2020 On 7/14/2020 at 10:11 AM, martin Baumann said: 2629-2630 2645-2646 2793-2794 are missing completely, are they still Brown Line? 2793-2794 went back to blue line i’m currently on 2793 Quote
chicagocubs6323 Posted July 18, 2020 Report Posted July 18, 2020 On 7/16/2020 at 8:01 PM, artthouwill said: if enough 2600s go into disrepair, you might see 6000s on the Blue Line still. A scant few might run the full route, but I think they would try to limit those cars to service between UIC and ORD And you're right 1 4 Quote
scotthilly Posted July 27, 2020 Report Posted July 27, 2020 I swear I just saw a Red Line train with 2600’s and 3200’s (3348 was the only number I for sure saw) at Fullerton. what gives? Haven’t had 2600’s on there since the 5000’s. Quote
artthouwill Posted July 27, 2020 Report Posted July 27, 2020 15 minutes ago, scotthilly said: I swear I just saw a Red Line train with 2600’s and 3200’s (3348 was the only number I for sure saw) at Fullerton. what gives? Haven’t had 2600’s on there since the 5000’s. I think you actually saw a BROWN Line teain. The Brown Line has a mix of 2600s and 3200s. Expect more 2600s to be added to the Brown Line as more 3200s head to the Blue Line. Quote
scotthilly Posted July 28, 2020 Report Posted July 28, 2020 25 minutes ago, artthouwill said: I think you actually saw a BROWN Line teain. The Brown Line has a mix of 2600s and 3200s. Expect more 2600s to be added to the Brown Line as more 3200s head to the Blue Line. No, I swear it was Red and had Howard signs. It went over me headed north while I was walking south of Fullerton. I pulled up the CTA site and the tracker said a Howard train was approaching (like the one I saw) and the next brown was 8 mins. Quote
Marcin Posted July 28, 2020 Report Posted July 28, 2020 4 hours ago, scotthilly said: No, I swear it was Red and had Howard signs. It went over me headed north while I was walking south of Fullerton. I pulled up the CTA site and the tracker said a Howard train was approaching (like the one I saw) and the next brown was 8 mins. When did you see the Train? Quote
chicagocubs6323 Posted July 28, 2020 Report Posted July 28, 2020 4 hours ago, scotthilly said: No, I swear it was Red and had Howard signs. It went over me headed north while I was walking south of Fullerton. I pulled up the CTA site and the tracker said a Howard train was approaching (like the one I saw) and the next brown was 8 mins. Or it could be the fact the 5000s are pretty dirty right now and haven't been washed since last year. Quote
artthouwill Posted July 28, 2020 Report Posted July 28, 2020 6 hours ago, chicagocubs6323 said: Or it could be the fact the 5000s are pretty dirty right now and haven't been washed since last year. But in his original post he claimed 3348 was one of the cars. Quote
chicagocubs6323 Posted July 28, 2020 Report Posted July 28, 2020 2 hours ago, artthouwill said: But in his original post he claimed 3348 was one of the cars. Could've been 5348. I can confuse a 3 and a 5 when looking at it from a distance. Quote
artthouwill Posted July 28, 2020 Report Posted July 28, 2020 2 minutes ago, chicagocubs6323 said: Could've been 5348. I can confuse a 3 and a 5 when looking at it from a distance. I agree. I also wondered if he possibly saw a Purple Line train going only to Howard. It's possible he saw 2 different trains, a Brown Line train while he was on the street and a Red or Purple by the time he was on the platform. Quote
Shannoncvpi Posted July 28, 2020 Report Posted July 28, 2020 9 hours ago, chicagocubs6323 said: Or it could be the fact the 5000s are pretty dirty right now and haven't been washed since last year. Yea I always wondered how tf the red line trains get so dirty before the rest of em be looking old AF after a year or 2 Quote
artthouwill Posted July 28, 2020 Report Posted July 28, 2020 14 minutes ago, Shannoncvpi said: Yea I always wondered how tf the red line trains get so dirty before the rest of em be looking old AF after a year or 2 The Red Line trains run in the middle of the Dan Ryan Expressway where the trains pick up mud, snow, salt from passing traffic. Quote
MTRSP1900-CTA3200 Posted July 28, 2020 Report Posted July 28, 2020 41 minutes ago, Shannoncvpi said: Yea I always wondered how tf the red line trains get so dirty before the rest of em be looking old AF after a year or 2 24 minutes ago, artthouwill said: The Red Line trains run in the middle of the Dan Ryan Expressway where the trains pick up mud, snow, salt from passing traffic. Not to mention 24/7 there and in the older of the two Chicago subway tunnels built. Also the Dan Ryan is the busiest highway in the state, especially when combined with the Kennedy. Fitting for the busiest CTA rail line, and I can only remember seeing bigger highways when I visited Los Angeles. More mess to go around, combined with less downtime for the rail cars to get some cleaning because of the operating hours. Quote
Marcin Posted July 28, 2020 Report Posted July 28, 2020 20 hours ago, scotthilly said: I swear I just saw a Red Line train with 2600’s and 3200’s (3348 was the only number I for sure saw) at Fullerton. what gives? Haven’t had 2600’s on there since the 5000’s. Do you remember if the car you saw was wrapped? Car 5348 on Red Line is wrapped. Maybe you mistaken a 5 with a 3. Quote
Marcin Posted July 28, 2020 Report Posted July 28, 2020 5 hours ago, artthouwill said: I agree. I also wondered if he possibly saw a Purple Line train going only to Howard. It's possible he saw 2 different trains, a Brown Line train while he was on the street and a Red or Purple by the time he was on the platform. Purple Line doesn't end at Howard going NB. Quote
artthouwill Posted July 28, 2020 Report Posted July 28, 2020 1 hour ago, Marcin said: Purple Line doesn't end at Howard going NB. Technically no. However there are some trips that do end at Howard. Why? I don't know. But there's always been some downtown trips that ended at Howard. Quote
Marcin Posted July 28, 2020 Report Posted July 28, 2020 7 minutes ago, artthouwill said: Technically no. However there are some trips that do end at Howard. Why? I don't know. But there's always been some downtown trips that ended at Howard. When? I don't think NB Purple ends at Howard. How do you know? Quote
artthouwill Posted July 28, 2020 Report Posted July 28, 2020 6 minutes ago, Marcin said: When? I don't think NB Purple ends at Howard. How do you know? I have seen them personally. It's not a bunch, maybe one or two. The last time I saw one was in the morning rush. Don't remember when. Quote
Marcin Posted July 28, 2020 Report Posted July 28, 2020 49 minutes ago, artthouwill said: I have seen them personally. It's not a bunch, maybe one or two. The last time I saw one was in the morning rush. Don't remember when. I wonder why? Do you know why car 5714, a Red Line car, operates on Purple Line at least 4 weeks? Quote
Marcin Posted July 28, 2020 Report Posted July 28, 2020 1 hour ago, artthouwill said: I have seen them personally. It's not a bunch, maybe one or two. The last time I saw one was in the morning rush. Don't remember when. On Purple Line schedule, no NB Train ends at Howard. I'd might check the AM Rush service on Train Tracker soon. Quote
