NewFlyerMCI Posted June 21, 2020 Author Report Posted June 21, 2020 It seems this is CTA’s new style of bus stop sign, I like it. Definitely easier to tell what routes are frequent/infrequent or more likely/less likely to be running at first glance. 2 Quote
jajuan Posted June 21, 2020 Report Posted June 21, 2020 17 hours ago, NewFlyerMCI said: Gotcha, thanks. I only noticed to today cause I saw a 55N come in and change to the 59, which then made me realize I’ve never seen the 165, 63W, 55A or 55N (I don’t even know what bay the 55A/N even stop at) at Midway before (under those routes at least) and I’ve only seen the 62H once. I don’t know how I miss them honestly, I’m usually at Midway for at least 10-30 minutes Tues-Sat. Oh well. I double checked today, and there's no interline. 63W stands alone to itself as a separately operated route on Sundays. So I stand corrected by myself on that part. Quote
rvwnsd Posted June 22, 2020 Report Posted June 22, 2020 9 hours ago, NewFlyerMCI said: It seems this is CTA’s new style of bus stop sign, I like it. Definitely easier to tell what routes are frequent/infrequent or more likely/less likely to be running at first glance. CTA's bus stop signs are, in my opinion, the best I've seen in the US. this is a nice enhancement to multi-route signs where the map is impractical. 3 Quote
sht6131 Posted June 22, 2020 Report Posted June 22, 2020 6 hours ago, rvwnsd said: CTA's bus stop signs are, in my opinion, the best I've seen in the US. this is a nice enhancement to multi-route signs where the map is impractical. The 50`s and 60`s signs were not that bad either. Had perfect route descriptions of the routes. The color enhancements of the above sign improves the signs I described as it clearly brings brings out the route descriptions. I still believe money could be saved if the route description was worded for all directions by beginning with (operates between via etc.) I think most passengers know which direction they want to go. Quote
Shannoncvpi Posted June 23, 2020 Report Posted June 23, 2020 Have another other drivers seen they buses mostly empty today compared to a few days ago I guess people are broke since cta said u gotta pay again or lost they bus cards Quote
MrH345 Posted June 23, 2020 Report Posted June 23, 2020 34 minutes ago, Shannoncvpi said: Have another other drivers seen they buses mostly empty today compared to a few days ago I guess people are broke since cta said u gotta pay again or lost they bus cards Definitely lighter than usual. At one point I was a few minutes hot. I’m so used to rolling hard, because after the first few stops I’d already picked 15 plus Quote
Shannoncvpi Posted June 23, 2020 Report Posted June 23, 2020 1 hour ago, MrH345 said: Definitely lighter than usual. At one point I was a few minutes hot. I’m so used to rolling hard, because after the first few stops I’d already picked 15 plus Dam I know most of my route today through the hood was empty Quote
rvwnsd Posted June 23, 2020 Report Posted June 23, 2020 17 hours ago, sht6131 said: The 50`s and 60`s signs were not that bad either. Had perfect route descriptions of the routes. The color enhancements of the above sign improves the signs I described as it clearly brings brings out the route descriptions. I still believe money could be saved if the route description was worded for all directions by beginning with (operates between via etc.) I think most passengers know which direction they want to go. Totally agree. Sometimes, I think the narrative was more useful than the map. 1 Quote
NewFlyerMCI Posted June 23, 2020 Author Report Posted June 23, 2020 On 6/22/2020 at 7:59 AM, sht6131 said: I still believe money could be saved if the route description was worded for all directions by beginning with (operates between via etc.) I think most passengers know which direction they want to go. This is often not the case with the amount of times people have asked me is such and such stop going the right way ?. The red line detours (59, 75, etc) often lead to confusion ? Quote
NewFlyerMCI Posted June 23, 2020 Author Report Posted June 23, 2020 Noticed that the sign that lists which routes serve which bays at Midway has the owl sign next to the 55 but the N55 doesn’t go to Midway. 55A/55N also aren’t on that sign either Quote
NewFlyerMCI Posted June 24, 2020 Author Report Posted June 24, 2020 The 2400s were on the platform today at Midway. Didn’t realize there was a second 4-car set there, I’ve only seen the one 6-car set IMG_7301.MOV IMG_7304.MOV IMG_7296.MOV Quote
Shannoncvpi Posted June 24, 2020 Report Posted June 24, 2020 1 hour ago, NewFlyerMCI said: The 2400s were on the platform today at Midway. Didn’t realize there was a second 4-car set there, I’ve only seen the one 6-car set IMG_7301.MOV IMG_7304.MOV IMG_7296.MOV Dam nice catch bro I did see a train leavinf 63rd rail yard this morning Quote
NewFlyerMCI Posted June 24, 2020 Author Report Posted June 24, 2020 5 hours ago, Shannoncvpi said: Dam nice catch bro I did see a train leavinf 63rd rail yard this morning These have been here for a while, at least 3-4 and maybe longer than that (the 6-car set at least, the 4-car has either been positioned in such a way, I can’t see it when my train leaves/arrives Midway or it truly hasn’t been in the yard before today Quote
NewFlyerMCI Posted June 24, 2020 Author Report Posted June 24, 2020 Well, a group of bikers has taken over the intersection of Michigan/Ida B in protest. Had to high tail it from Van Buren to Monroe to catch my bus, which is what I get for being lazy and not just getting on the green line. I am surprised Harrison, Adams/Wabash & Harold Washington Library haven’t yet been closed down ? Quote
Shannoncvpi Posted June 25, 2020 Report Posted June 25, 2020 4 hours ago, NewFlyerMCI said: These have been here for a while, at least 3-4 and maybe longer than that (the 6-car set at least, the 4-car has either been positioned in such a way, I can’t see it when my train leaves/arrives Midway or it truly hasn’t been in the yard before today Aw ok Quote
Shannoncvpi Posted June 26, 2020 Report Posted June 26, 2020 Is it bad or not that I had to ask the lady at the train station at 63rd & cottage which bus card would I need just to go downtown to traffic court & back I was like dam I didnt know this but I work for these people forgot they even had a bus card that was good for 2 hours ?? Quote
artthouwill Posted June 26, 2020 Report Posted June 26, 2020 50 minutes ago, Shannoncvpi said: Is it bad or not that I had to ask the lady at the train station at 63rd & cottage which bus card would I need just to go downtown to traffic court & back I was like dam I didnt know this but I work for these people forgot they even had a bus card that was good for 2 hours ?? It's real bad. I thought CTA employees rode free. 2 Quote
Shannoncvpi Posted June 26, 2020 Report Posted June 26, 2020 2 hours ago, artthouwill said: It's real bad. I thought CTA employees rode free. U know what I forgot all bout the dam bus card I aint never used it since I got it its in my wallet collecting dust I just had to go downtown for traffic court which its still closed but I spend $3 on a 2 hour bus card Quote
YoungBusLover Posted June 28, 2020 Report Posted June 28, 2020 I will never understand having artics out past 9 pm on king drive of all places.... Quote
NewFlyerMCI Posted June 28, 2020 Author Report Posted June 28, 2020 2 hours ago, YoungBusLover said: I will never understand having artics out past 9 pm on king drive of all places.... I see only one, could it just be a driver heading back south trying to get some last few hours in? Also, this makes me realize the 4 could probably run out of 103rd when/if all these garage assignments go back to normal Quote
YoungBusLover Posted June 28, 2020 Report Posted June 28, 2020 1 hour ago, NewFlyerMCI said: I see only one, could it just be a driver heading back south trying to get some last few hours in? Also, this makes me realize the 4 could probably run out of 103rd when/if all these garage assignments go back to normal The thing is they've been quietly running them after peak rush periods during the work week and now the weekends. Quote
Shannoncvpi Posted June 28, 2020 Report Posted June 28, 2020 7 hours ago, YoungBusLover said: The thing is they've been quietly running them after peak rush periods during the work week and now the weekends. I said the same but since I guess more things opened back up more people floating around late at night now Quote
Sam92 Posted June 28, 2020 Report Posted June 28, 2020 11 hours ago, YoungBusLover said: I will never understand having artics out past 9 pm on king drive of all places.... 9 hours ago, NewFlyerMCI said: I see only one, could it just be a driver heading back south trying to get some last few hours in? Also, this makes me realize the 4 could probably run out of 103rd when/if all these garage assignments go back to normal 7 hours ago, YoungBusLover said: The thing is they've been quietly running them after peak rush periods during the work week and now the weekends. 23 minutes ago, Shannoncvpi said: I said the same but since I guess more things opened back up more people floating around late at night now That was actually from an interline. Later in the day and into the evening 3 and 4 interline at Chicago state terminal. And since #4 started getting regular artics again what you're seen is an artic popping up on #3 that was likely a #4 run earlier in the day. Matter of fact the screenshot shows that the artic was on the #4 most of the day before it did a run on King drive. Idk if it's still a thing or not but I actually remember a few overnight #4's would do a run on King drive before interlining and doing night car Quote
YoungBusLover Posted June 28, 2020 Report Posted June 28, 2020 21 minutes ago, Sam92 said: That was actually from an interline. Later in the day and into the evening 3 and 4 interline at Chicago state terminal. And since #4 started getting regular artics again what you're seen is an artic popping up on #3 that was likely a #4 run earlier in the day. Matter of fact the screenshot shows that the artic was on the #4 most of the day before it did a run on King drive. Idk if it's still a thing or not but I actually remember a few overnight #4's would do a run on King drive before interlining and doing night car You're correct on the interline part. However, most runs transition from king drive to cottage grove at time of night but I should of mentioned this yesterday evening that this was a late pull out from the garage which I found to be quite strange, the past few weekends runs haven't been getting filled throughout the course of the day on certain streets such as 79th,King Drive and Cottage Grove. I was lucky enough to get a relief last night while operating on 87th. I came straight into the garage area and saw three 4000's sitting idle waiting to pullout and one run was 380 which is a King Drive run while the other two were 678 and 679 which were night-owls on 79th. Normally all PM runs past 8 are filled will 7900's and the occasional #1000's. Quote
