5 hours ago, renardo870 said:
I thought the Foster entrance was a temporary entrance for the temporary Argyle station 🚉. Foster will not have a permanent entrance for neither Argyle nor Berwyn when RPM is completed from my knowledge, although Berwyn would've been the logical choice for a Foster entrance.
With statements in connection with the accessibility plan, including that new stations must meet code, including an emergency exit, there's going to be an auxiliary entrance/exit somewhere.
IMG_1372.thumb.jpeg.d4983d0d1b424a949a6e48c75f3f8bdb.jpeg5307 sporting the RPM wrap but 5308 and the rest of the train cars on that consist had no wrap. It would’ve looked better having the full 8 car consist of this train wrapped.
I caught this train at Belmont southbound around 3pm yesterday.
  • 3 months later...
There was a Construction Report for May, and at the Board Meeting, your Chief Infrastructure Officer William Moody said that the Clark Jct. work is done (to the extent that all 5 tracks are in service), and the LBMM is nearing the finish line, with station work at various stages.
20 minutes ago, artthouwill said:
Glad to hear this.  Now tell me when Phase 2 is set to begin.
You could look at the Next Phases page, including the presentations, which said about 1-1/2 years ago:
  • Haha 1
6 hours ago, renardo870 said:
New RPM routing and station layout for Lawrence, Argyle, Berwyn and Bryn Mawr - Hollywood with elevator 🛗 and escalators.
Why would it use Winona middle track instead of Track 3?
4 hours ago, Tcmetro said:
Track 3 is still covered by the temporary Argyle station. Assuming that it will move over once demolition is complete.
Thanks. I shudda figured it out from the bigger black box at Argyle on the Stage B map.
Next question: Any word yet on permanent bus routings? For instance, with both the Bryn Mawr and Hollywood entrances being accessible, could 84 be routed via Hollywood>Sheridan>Bryn Mawr instead of using a triangle at DLSD?
On 7/3/2025 at 4:17 PM, Tcmetro said:
They've put notices out that the 81 and 84 will return to pre-construction routings.
There are also July 20 bus timetables showing that the 92 and 146 terminal has been moved from Broadway back to the Berwyn Red Line station, which is consistent with the notice above that the station will have a bus operator restroom.
Starting here in the August CT Board meeting video is a presentation of the effect of the reopening of the 4 RPM stations, with recovery of passenger counts to pre-COVID levels already. Also mentioned was the effect of the Damen station increasing ridership at other Green Line stations.
The Next Phases study is due to be complete by the end of 2025, per the webpage. It read 2024 until recently.
https://www.transitchicago.com/rpm/next-phases/
Quote
The study is expected to be finalized in 2025. Completing this critical planning phase will allow the CTA to launch the next steps in the process, which includes engineering work, conducting a National Environmental Policy Act (NEPA) environmental review, and identifying funding for implementation.
NBC 5 news story relaying that further progress on RPM improvements and the start of the Red Line extension to 130th could be delayed because the Trump administration paused $2.1 billion in Chicago infrastructure funding, part of which was meant for CTA for RPM and RLE. It stems from both a stated Trump strategy of pausing infrastructure funding to Democrat led cities after the federal government went into the current shutdown and from his push to press a reduction or end to DEI policies in lower levels of government and the private sector following the end of said policies in much of federal government operations. Because it's relevant to both RPM and RLE, I couldn't decide at first whether to stick this here or in the RLE thread.
