Busjack Posted October 12, 2024 Report Posted October 12, 2024 5 hours ago, renardo870 said: I thought the Foster entrance was a temporary entrance for the temporary Argyle station 🚉. Foster will not have a permanent entrance for neither Argyle nor Berwyn when RPM is completed from my knowledge, although Berwyn would've been the logical choice for a Foster entrance. With statements in connection with the accessibility plan, including that new stations must meet code, including an emergency exit, there's going to be an auxiliary entrance/exit somewhere. Quote
Busjack Posted December 23, 2024 Report Posted December 23, 2024 A milestone: last span of LBMM installed (Construction Report) : Quote
Javi75 Posted February 6 Report Posted February 6 5307 sporting the RPM wrap but 5308 and the rest of the train cars on that consist had no wrap. It would’ve looked better having the full 8 car consist of this train wrapped. 1 Quote
Javi75 Posted February 6 Report Posted February 6 Just now, Javi75 said: 5307 sporting the RPM wrap but 5308 and the rest of the train cars on that consist had no wrap. It would’ve looked better having the full 8 car consist of this train wrapped. I caught this train at Belmont southbound around 3pm yesterday. Quote
Busjack Posted May 14 Report Posted May 14 There was a Construction Report for May, and at the Board Meeting, your Chief Infrastructure Officer William Moody said that the Clark Jct. work is done (to the extent that all 5 tracks are in service), and the LBMM is nearing the finish line, with station work at various stages. Quote
TaylorTank1229 Posted June 18 Report Posted June 18 The new modernized Bryn Mawr, Berwyn, Argyle, and Lawrence Red Line train stations set to open up for business on July 20th! https://www.transitchicago.com/mayor-johnson-announces-four-new-fully-accessible-cta-red-line-stations-will-open-july-20/ 3 Quote
artthouwill Posted June 18 Report Posted June 18 1 hour ago, TaylorTank1229 said: The new modernized Bryn Mawr, Berwyn, Argyle, and Lawrence Red Line train stations set to open up for business on July 20th! https://www.transitchicago.com/mayor-johnson-announces-four-new-fully-accessible-cta-red-line-stations-will-open-july-20/ Glad to hear this. Now tell me when Phase 2 is set to begin. Quote
Busjack Posted June 19 Report Posted June 19 20 minutes ago, artthouwill said: Glad to hear this. Now tell me when Phase 2 is set to begin. You could look at the Next Phases page, including the presentations, which said about 1-1/2 years ago: 1 1 Quote
renardo870 Posted July 3 Report Posted July 3 New RPM routing and station layout for Lawrence, Argyle, Berwyn and Bryn Mawr - Hollywood with elevator 🛗 and escalators. 1 Quote
Busjack Posted July 3 Report Posted July 3 6 hours ago, renardo870 said: New RPM routing and station layout for Lawrence, Argyle, Berwyn and Bryn Mawr - Hollywood with elevator 🛗 and escalators. Why would it use Winona middle track instead of Track 3? Quote
Tcmetro Posted July 3 Report Posted July 3 Track 3 is still covered by the temporary Argyle station. Assuming that it will move over once demolition is complete. 3 Quote
Mr.NewFlyer1279 Posted July 3 Report Posted July 3 1 hour ago, Busjack said: Why would it use Winona middle track instead of Track 3? they will be taking down the temporary station at argyle. Quote
Busjack Posted July 3 Report Posted July 3 4 hours ago, Tcmetro said: Track 3 is still covered by the temporary Argyle station. Assuming that it will move over once demolition is complete. Thanks. I shudda figured it out from the bigger black box at Argyle on the Stage B map. Next question: Any word yet on permanent bus routings? For instance, with both the Bryn Mawr and Hollywood entrances being accessible, could 84 be routed via Hollywood>Sheridan>Bryn Mawr instead of using a triangle at DLSD? Quote
Tcmetro Posted July 3 Report Posted July 3 They've put notices out that the 81 and 84 will return to pre-construction routings. 1 Quote
Busjack Posted July 24 Report Posted July 24 On 7/3/2025 at 4:17 PM, Tcmetro said: They've put notices out that the 81 and 84 will return to pre-construction routings. There are also July 20 bus timetables showing that the 92 and 146 terminal has been moved from Broadway back to the Berwyn Red Line station, which is consistent with the notice above that the station will have a bus operator restroom. Quote
Busjack Posted August 13 Report Posted August 13 Starting here in the August CT Board meeting video is a presentation of the effect of the reopening of the 4 RPM stations, with recovery of passenger counts to pre-COVID levels already. Also mentioned was the effect of the Damen station increasing ridership at other Green Line stations. Quote
Tcmetro Posted August 26 Report Posted August 26 The Next Phases study is due to be complete by the end of 2025, per the webpage. It read 2024 until recently. https://www.transitchicago.com/rpm/next-phases/ Quote The study is expected to be finalized in 2025. Completing this critical planning phase will allow the CTA to launch the next steps in the process, which includes engineering work, conducting a National Environmental Policy Act (NEPA) environmental review, and identifying funding for implementation. Â Quote
jajuan Posted October 3 Report Posted October 3 NBC 5Â news story relaying that further progress on RPM improvements and the start of the Red Line extension to 130th could be delayed because the Trump administration paused $2.1 billion in Chicago infrastructure funding, part of which was meant for CTA for RPM and RLE. It stems from both a stated Trump strategy of pausing infrastructure funding to Democrat led cities after the federal government went into the current shutdown and from his push to press a reduction or end to DEI policies in lower levels of government and the private sector following the end of said policies in much of federal government operations. Because it's relevant to both RPM and RLE, I couldn't decide at first whether to stick this here or in the RLE thread. 3 Quote
