4121 on the 53, running out of C
4007, 4015, 4016, 4032 & 4040 on the 79, running out of 7
4069, 4075, 4079, 4132, 4148, 4158, 4159, 4162, 4163, 4169 on the 20, running out of C
I hadn't realized just how many artics had moved (C didn't have any right?)
The 4300s are on the usual assignments out of 3 and NP
The 12 and 82 are seeing more consistent artic use (12 usually on the weekends and 82 usually during pm rush)
I seen 1 on the 20 forgot what bus number
Posted (edited)
I’m currently on 4014 on #4 and there’s another artic about 3-5 blocks ahead of us. There’s only 4 passengers but I assume part of that has to do with the bus in front of us. As I write, they’ve deployed a supervisor for the NB section at Cottage Grove & 67th, with a Chicago police SUV behind it (not sure if he’s with the supervisor or not)
EDIT: Passed 4012 & 4008 bunched together heading SB at Cottage & 63rd
EDIT2: Just boarded 4040 SB at Cottage & 61st with a medium size load, lot of people like me getting on at the Jewel Oscos, also saw 4017 headed NB. That’s at least 30 artics that have been sent to 7 and 6
Edited by NewFlyerMCI
4077, 4122, 4135 are all now at C, and are on the 53, along side 4069, 4079 & 4163
4010 and 4207 are at 77th, on the 79
4008, 4011, 4012, 4014, 4017, 4033, 4039 are now at 77th, on the 4
While the 20 & 53 seem to have an even ratio of artics, the 79 now only has 2 compared to the 5 from yesterday and the 4, which had none, now has 9, I think. These buses also still have their K stickers on, obv. This makes for a total on 25 artics gone, 14 to Chicago and 11 to 77th. For reference, these are the routes that have been mentioned or talked about the last couple of days and how they rank as busiest in the city,
  • 1st: 79
  • 4th: 4
  • 7th: 53
  • 10th: 82
  • 11th: 20
  • 15th: 63
  • 18th: 12
4CC_1.jfif 4CC_2.jfif
3 hours ago, NewFlyerMCI said:
4002 on 77, running out of Kedzie. Is this a school trip and they're just running it cause it's on the schedule?
artics come off of 156 do a WB trip on belmont to kimball and then do trip to kedzie garage or congress or 31st lawndale
54 minutes ago, Sam92 said:
To where?
To 77th, we've had so many issues as of late on 79th, theirs a lot of runs not getting filled but especially 79th. I basically had to pull-out due to a run not being on the street to relief and roughly pulling right back in when I didn't get a relief east on 79th.
Damn you probably passed by me ? ??
Yea they started that one of the he girls came back to the garage saying that she had to do that after ending the 156
11 hours ago, YoungBusLover said:
Believe it or not 74th sent some drivers over to help fill runs today after they were done working the 75.
Dam bro y'all got even more drivers out take it easy out there bro it's a few over at K that's out
This started awhile back to help with overcrowding issues on the 77.  I think that was 2 years ago when it started.
@YoungBusLover Do you know how they're assigning artics to routes at 77th? It seems to be pretty consistent at Chicago (even mix on the 20 & 53) but at 77th it seems to be at random. At first it was 79 only, then a mix of the 79 & 4, then just the 4 and now just the 79, and there's one on the 3 as well? Are they prioritizing them all on one route, or should be expect to see something similar to what they're doing with the 20 & 53
I honestly have no idea, they've created special runs for 79th street using a mix of 40-60 footers that are used during the day to help alleviate crowding EB/WB crowds coming to the red line. I call those extra runs helpers in a sense since they only go from either the red line to the lakefront or the red line to western. Some veteran operators that have experience with artics are using them with there regular runs which is probably why Cottage grove had a lot of them out yesterday and 79th only had 2 from what I saw. It all boils down to experience which to me 77th doesn't seem to have right now along with a lot of operators calling off and newer operators still getting trained, it's a fluid situation to say the least. I'm on the extra board today so I may be apart of the de-crowding efforts on 79th today.
Sounds like that relief on hand situation that someone here described as happening at 63rd red line the other day. And gotcha, thanks for the explanation.
Dam bro sound like 7 having a big problem with this & I thought it was more vets then rookies there but it's gone all work out I wouldn't be surprised if they sent drivers from other garages besides 6 to help yall
